better brakes..
Old Jan 12, 2014 | 08:57 PM
Frankieg35's Avatar
My regular brakes suck, i gotta double pump them so they bite.. I plan on upgrading to brembos..
Old Jan 12, 2014 | 10:04 PM
totopo's Avatar
Errrr, they're not like that because they're stock. If you need to pump them something is wrong with your braking system. You should have a mechanic look at it.
Old Jan 13, 2014 | 09:09 AM
Mustang5L5's Avatar
Common G35 issue.
Check your rear calipers and see if any of the slide pins are seized in place. This locks the caliper so it can't adjust as the pads wear. So you are double pumping to "take up the slack"
I've had this issue twice on my car. Both times were rear calipers. Had to replace the caliper ($50ish off rockauto.com) and my braking was MUCH better after fixing the mechanical issue. When in good working condition, the brakes on my G35x have a better feel and response than the brakes on my Benz C300 with sport brake package.
I've seen a lot of guys experience this issue, so def check your rear brakes.
Old Jan 13, 2014 | 02:47 PM
Frankieg35's Avatar
I'll have to check it out.. They stop decent but when I double pump them I feel it bite really hard..
Old Jan 14, 2014 | 12:09 PM
gary c's Avatar
You have issues...^...factory brakes normally work good! Having to pump your pedal tells me you need to have a brake shop check them out. Past experience tells me you have a caliper failure that keeps the pads from making contact when pedal is pressed. Find an independent brake shop in your area, dealerships are just "Parts Swappers" until they find the cause! You don't need Brembos, they don't work any better than OE brakes for DD!
Gary
Frankieg35
Mar 20, 2016 09:42 PM
grisafeballer
Feb 12, 2013 08:30 PM
G35Philiac
Feb 11, 2013 02:34 AM
Charju
Nov 30, 2012 12:36 PM
Frankieg35
May 19, 2012 09:28 PM
