weird noise when braking.
Old Jan 12, 2014 | 09:20 PM
Sean13's Avatar
I have an 06 coupe with g37 wheel on it. Recently the wheel on the driver side making this weird noise when I brake or any street bumps. I took the wheel off and checked, everything looks normal to me, so I'm clueless now. please help, your help will be greatly appreciate. Thanks.
Ps: Below is the link to the video.
http://s1282.photobucket.com/user/se...698d7.mp4.html
Old Jan 12, 2014 | 09:24 PM
Sean13's Avatar
would it be my shock?
Old Jan 12, 2014 | 10:11 PM
Urbanengineer's Avatar
It very well could be a blown suspension piece. Check connections for loose nuts and bolts first.
Old Jan 12, 2014 | 10:25 PM
Sean13's Avatar
I checked all bolts are tight and nothing seem broken at all.
Old Jan 12, 2014 | 11:15 PM
Tukeeg35's Avatar
How are your bushings looking?
Old Jan 12, 2014 | 11:40 PM
Sean13's Avatar
they all look very normal.
Old Jan 12, 2014 | 11:43 PM
Sean13's Avatar
it only making noises when I brake while the wheel is rolling and kinda make a pretty the same noise when I ran on the curb on my driveway.
Old Jan 13, 2014 | 01:02 AM
Check your compression rod Ball joints/bushings or w/e. Are you experiencing "Clunk" ?
Old Jan 13, 2014 | 11:15 PM
Void's Avatar
Its probably the fact you have royal blue calipers with pink rims.
Old Jan 13, 2014 | 11:59 PM
ScraggleRock's Avatar
Did you do any work to the suspension or wheels before the noise started? Or did it start randomly?
Old Jan 14, 2014 | 01:06 AM
Sean13's Avatar
thanks and I really appreciated for all the input. I brought to the shop today and found out that one of the nut of the lower are was loose. Tight it up and problem was solved. Just wanna throw it out there for future references
Old Jan 14, 2014 | 01:21 AM
Haha that's EXACTLY what mine was.
Old Jan 14, 2014 | 12:53 PM
Sean13's Avatar
it was the one toward the brake.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
