Post Your Spring/Coilover + Alignment setup
Old Feb 22, 2014 | 03:23 PM
PLENUMCOUPE's Avatar
Post your lowering spring or coilover setup and the alignment suspension parts you paired with them (if applicable).
Include brand names, prices (not shipped), and if you have springs, the amount of drop. Looking to compare setups and prices. Example of the setup Im thinking about getting:
Tein S-tech $172 F: -1.2, R: -0.9
Kinetix Front Camber arms $245
SPC Toe bolts $25
Attached Thumbnails Post Your Spring/Coilover + Alignment setup-image-2690901250.jpg   Post Your Spring/Coilover + Alignment setup-image-139545653.jpg
Old Feb 22, 2014 | 03:27 PM
Also if desired include the shocks/struts paired with springs. PLEASE include any blown shocks, wheel rubbing, or any other problems you had so we can avoid certain brands.
Old Feb 22, 2014 | 05:51 PM
Tukeeg35's Avatar
Ill play,
Stock shocks/Eibach Pro-kit (bought used for $80)
pretty sure I got the Z kit cuz im dropped 1.6 in front and 1.1 in the rear
SPC front and rear camber kit/toe bolts (~$550 shipped if i remember correctly)
Added the SPC spacer kit in the front and it screwed with my ABS so bad I had to take them out.
Old Feb 22, 2014 | 05:59 PM
Urbanengineer's Avatar
Originally Posted by PLENUMCOUPE
Post your lowering spring or coilover setup and the alignment suspension parts you paired with them (if applicable). Include brand names, prices (not shipped), and if you have springs, the amount of drop. Looking to compare setups and prices. Example of the setup Im thinking about getting: Tein S-tech $172 F: -1.2, R: -0.9 Kinetix Front Camber arms $245 SPC Toe bolts $25
That's a fairly reasonable price for the drop. Nice piecing.
Originally Posted by Tukeeg35
Ill play, Stock shocks/Eibach Pro-kit (bought used for $80) pretty sure I got the Z kit cuz im dropped 1.6 in front and 1.1 in the rear SPC front and rear camber kit/toe bolts (~$550 shipped if i remember correctly) Added the SPC spacer kit in the front and it screwed with my ABS so bad I had to take them out.
Why are these camber kits so expensive? They are a hunk of metal that's adjustable.
Old Feb 22, 2014 | 11:58 PM
That's a fairly reasonable price for the drop. Nice piecing. Why are these camber kits so expensive? They are a hunk of metal that's adjustable.
Now thinking about D2 springs- $130, -1.25"
And I think were all a little baffled with the price of camber arms
Old Feb 23, 2014 | 02:07 AM
Shawno72's Avatar
Sub'd
Old Feb 23, 2014 | 12:49 PM
Bump lets get it goin
Old Feb 25, 2014 | 11:10 AM
Blue Dream's Avatar
I drove ttrank's car solo
Nothing to be baffled about. The reason that the SPC and SPL kits are popular even though they are more expensive than the rest is that they give actual positive camber adjustment up front. None of the cheaper brands do even though they claim they do so those of us that are dropped significantly need the more expensive kits to correct the large camber difference. I'm dropped 3" on an 05 sedan and am in factory spec with my alignment on all 4 corners.
I'm running Tanabe Pro5 coils, SPL front a-arms, Stillen rear camber arms, and SPC toe bolts.
Old Feb 25, 2014 | 12:05 PM
LoSt180's Avatar
OEM revised 350Z springs and shocks. F: .75" R: .75" (with perch mod) Price: free after selling the matching 06 Sport parts
SPC Front and Rear camber arms (not using toe bolts in rear, got good adjustment with just the arms on a mild drop)
Fronts were purchased from vendor around $300. Rears were a "new, never installed" local deal.
Old Mar 2, 2014 | 10:59 AM
Shawno72's Avatar
Here I am on swift springs with rear spring mount mod. 1"/1.1" with spc rear camber and toe kit. Front camber arms will come depending how the front tires wear. 20mm H&R spacers on the rear, 15mm to come for the front.
Post Your Spring/Coilover + Alignment setup-6efcpkp.jpg
Post Your Spring/Coilover + Alignment setup-rzy2rop.jpg
Post Your Spring/Coilover + Alignment setup-ssewtkb.jpg
Post Your Spring/Coilover + Alignment setup-awpwldh.jpg
Old Mar 2, 2014 | 11:08 AM
Nothing to be baffled about. The reason that the SPC and SPL kits are popular even though they are more expensive than the rest is that they give actual positive camber adjustment up front. None of the cheaper brands do even though they claim they do so those of us that are dropped significantly need the more expensive kits to correct the large camber difference. I'm dropped 3" on an 05 sedan and am in factory spec with my alignment on all 4 corners. I'm running Tanabe Pro5 coils, SPL front a-arms, Stillen rear camber arms, and SPC toe bolts.
You say cheaper brands don't, how bout kinetix front arms? This is from the product description on their website:
These arms will allow 1.5 degrees of positive camber, and 1.5 degrees of negative camber from the factory settings. So if your car is lowered 1.5" and the front camber is sitting at 2 degrees negative camber, these arms will allow you to bring them back out to .5 degrees negative camber.
Old Mar 2, 2014 | 12:00 PM
Shawno72's Avatar
This is what I'm looking at buying. From eBay
Brand New
Kinetix Racing
Front Upper A-Arms w/ Camber Adjustment
Applications: Please see compatibility link above.
2003-2006 350Z / G35 (All Trims and Models)
2007 G35 Coupe only (All Trims and Models)
2003-2008 FX35 (All Trims and Models)
Complete upper control arm replacement allowing positive and negative camber adjustment of the front wheels. These arms will allow you to either add positive camber to your wheels (EXTEND tire life) or to add negative camber (increase handling). OUR ARMS OFFER THE MOST POSITIVE ADJUST-ABILITY OF ANY ARM ON THE MARKET (longer tire life!) The front suspension from the factory allows zero camber adjust-ability which can become a problem especially when lowering your car. Race enthusiasts also wish to add more negative camber to increase their handling without having to "slam" their car to achieve the desired camber. These arms will allow 1.5 degrees of positive camber, and 1.5 degrees of negative camber from the factory settings. So if your car is lowered 1.5" and the front camber is sitting at 2 degrees negative camber, these arms will allow you to bring them back out to .5 degrees negative camber.
These arms are completely TIG welded and offer a huge upgrade in strength over the factory arms. They use ENERGY SUSPENSION polyurethane bushings for increased responsiveness over the factory rubber bushings. They also use a high quality 3-piece Heim ball joint protected by a polyurethane red dust boot. These Heim joints offer the best in suspension responsiveness and smooth operation. These Heim joints are also highly serviceable and do not require any special tools to remove. The have Teflon coatings inside for "chatter" free operation for years. We have also included grease fittings for even easier serviceability.
Old Mar 2, 2014 | 12:39 PM
Pepper's Avatar
TEIN Flex Coilover Kit with EDFC
SPC camber kit up front
SPC rear camber kit
SPC toe bolts
-9 Camber all around and toe set to 0.
Old Mar 5, 2014 | 09:05 PM
Bump
Old Mar 5, 2014 | 09:31 PM
xFALCONS7x's Avatar
Swift Sport (red) springs with rear spring mount mod
KYB excell G Shocks
Spc Rear Camber arms with Toe bolts
Camber: -3 front -1.2 rear
Looks good but deff looking into getting Stance Super Sport coils pretty soon along with the SPL front camber arms.
Attached Thumbnails Post Your Spring/Coilover + Alignment setup-img_2343.jpg   Post Your Spring/Coilover + Alignment setup-img_2372.jpg
