Front camber kit?
Front camber kit?
So I am in the market for some camber kits. Currently, I am sitting on Z Tein S-Techs and running about -2 camber up front and about -3.5 in the rear. Im looking to go to pretty stanced at about -3.5-4 in the front and around -5 in the rear.
My question is this: I know I need a rear camber kit in order to run that amount of negative camber in the rear but was wondering if the front kit is as necessary? Also, if I will need the toe bolt for the rear as well or if the rear links that come with the kit are sufficient enough. Thanks all in advance.
EDIT: Also if anyone knows a good suspension shop in the San Diego area. Thanks!
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
