suspension noise??
Old Mar 18, 2014 | 04:59 AM
bishop977's Avatar
suspension noise??
does anyone know where the noise is coming from my suspension sound all screwed up.
https://www.dropbox.com/s/bxfoerkmhk...317_200921.mp4
Old Mar 18, 2014 | 09:49 AM
gary c's Avatar
There's only one way to figure out what's wrong with your suspension making those awful noises, take it to a independent brake/alignment shop. They'll put it on the rack and find what parts are worn out and replace them. You don't want to have the dealership do the work due to much higher costs and possibly quality of work!
Gary
Old Mar 19, 2014 | 12:14 AM
bishop977's Avatar
i recently change the control arm to whiteline poly. could that be the squeaking noise? i was thinking maybe endlink.
Old Mar 19, 2014 | 01:14 AM
hurleyguys's Avatar
i switched over to the poly bushings and i am getting a squeak also. you just have to lube them and make sure they are tight and it will go away, but control arms are kinda notorious for coming loose.
Old Jun 1, 2014 | 10:33 PM
bishop977's Avatar
Found out it was loose bolt hold the compression bushing
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
