SPC rear camber arms redesign coming?
Old Apr 15, 2014 | 10:11 AM
Speedster's Avatar
I was about to purchase a rear camber arm kit for my 2003 G35 sedan and heard of a redesign. I contacted a vendor who called SPC and apparently a new design is coming in a couple months. Only info I could get was they will be stronger. Anybody else heard anything? Wondering if I should wait or just get the current design if there are no issues anyways.
EDIT : found out that there is going to be a redesign but only for manufacturing process purposes that will not affect performance in anyway. The arms will be straight instead of having slight bend in them like the current generation
Old Apr 15, 2014 | 11:14 AM
DEMoLITIoN's Avatar
Have you seen the powered by max camber arms? Pair these up with an eccentric lockout kit and you will have the perfect permanent camber settings.
~ lifetime manufacturers defect warranty
~ All steel tubular construction
~ Teflon lined spherical bearings
~ Forged Clamping rod end receiver
~ Forged Clamping double threaded adjuster makes double sure your settings never come loose
~ Super long adjuster threads have the most thread overlap and more adjustability than anything on the market
~ Adjuster away from the subframe, on the knuckle side for easier adjustments
~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion
~ Laser cut reinforced mounting bracket
~ Copper and Gold plated finish
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
