Camber and toe questions
Old Apr 23, 2014 | 06:35 PM
g35loving's Avatar
So yesterday I put my god speed camber arms on(came with the car). The toe was way off so I got a alignment today. Camber is set at -6 degrees and after adjustments toe was -.5. I have toe arms to out on but the shop would not put them on. So my wife is driving the car and she calls me freaking out saying that it feels as if the car is wanting to slide on her in turns. Can this be because of a bad camber arm or the toe not being set to the proper setting?
Old Apr 23, 2014 | 06:37 PM
Jairen's Avatar
Post a pic of your alignment sheet.
Old Apr 23, 2014 | 06:49 PM
g35loving's Avatar
I didn't even see I had it until you asked. Looks like he messed with my camber too. It was -6 all the way around
Old Apr 23, 2014 | 06:50 PM
g35loving's Avatar
. There you go
Old Apr 23, 2014 | 06:52 PM
Urbanengineer's Avatar
This is -3. You are telling me you are doubling that? That seems like a wacky camber setting.
Old Apr 23, 2014 | 06:59 PM
g35loving's Avatar
I am on air ride with flared fenders. I have that camber so when I air out it will tuck in the fender well
Old Apr 23, 2014 | 07:10 PM
Interesting! Odd your shop wouldn't drill out toe bolts, the shop I went to specifically let me know if I had any aftermarket parts to put on they would have to make a permanent modification by drilling... (doing it right).
Old Apr 23, 2014 | 07:19 PM
g35loving's Avatar
This guy literally did not seem like he wanted to help me out at all and was trying to tell me that I need to put the camber back to stock. I know people run big camber with no problems so this is confusing me.
Old Apr 23, 2014 | 09:09 PM
Yeah he didn't know what he was doing. Where are you located maybe we can help you find a close by specialist. In Ohio we have Performance Alignment, Kentucky has Dynosty. Not sure about what part of Nor Carol your at.
Old Apr 23, 2014 | 09:18 PM
ScraggleRock's Avatar
Where do I start...
First, do not install those toe arms. Toe arms are the worst way to correct toe. Drill out the toe bolt hole and adjust properly.
Second, Godspeed arms are pooty. How did you even get -6 degrees camber? That is ridiculous. Your camber should be at about -1.4. When you have all that camber your car is only riding on like 3" of tire, so of course the rear wants to break loose. You've got 3500lbs riding on the contacts patch of a bicycle tire.
Old Apr 23, 2014 | 09:59 PM
g35loving's Avatar
Yea and I do not know of a specialist around here. I live in winston salem nc
Old Apr 23, 2014 | 10:01 PM
g35loving's Avatar
Originally Posted by Gdirtyfive55
Where do I start...
I believe it has been drilled out already but they can probably go more. And I have a lot more contact then that. 285/35 tire on a 11inch wide
Old Apr 23, 2014 | 10:06 PM
I understand, but pulling the inside top of the tire in that far, you pull the outside bottom of the tire off the ground. It may be touching the ground, but believe me it is not doing anything because the pressure and weight of the car is all concentrated on the inside bottom of the tire.
Old Apr 23, 2014 | 10:24 PM
shoult's Avatar
^This.
Old Apr 23, 2014 | 10:49 PM
g35loving's Avatar
I know what you are saying. I have had other big body cars with more camber and friends with sedans with around -8 camber with no problems. So it can be done with no swaying once the toe is fixed
