Tie Rod Bushing has Grease on it
Old May 30, 2014 | 02:05 PM
WyattT's Avatar
I heard a screaching/rubbing noise when I turn right this morning so I looked around the wheels when I got home. I did not notice anything loose but I did see grease on the bottom of the tie rod busing on the passenger side. The car has less than 65k on it and it does not seem like this would be something I need to replace this early. All of the articles I read on tie rod/ball joint/bushing replacement here are about older cars with a lot more miles.
I was in a front end accident that had me replace the bumper and headlight. I was wondering if this accident could have something to do with the grease leaking. Is this even what is causing the noise? I also very occasionally hear a knock when going over a hard bump.
Old May 30, 2014 | 02:21 PM
coffeysm's Avatar
Maybe the ball joint on the spindle or compression rod is torn?
Old May 30, 2014 | 06:49 PM
WyattT's Avatar
Yeah, I assume its the ball joint or just a torn bushing but I am wondering whether or not it broke/tore because of the accident. The other side is grease free. It does not seem like this is something that would go out this early from wear and ... tear ...
I think I could replace it myself but if I can get it for free. Accident was in the fall around oct.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
