Rear Pad Change 08g35x
Old Jul 10, 2014 | 01:46 PM
WyattT's Avatar
08 g35x. I changed my fronts no problem but when I went to change the backs the rear pad will not move. All I have done so far is remove the top and loosened the bottom bolt from the caliper bracket and swung it down. The outside one came out easy but the inside will not budge.
I don't want to try to force it if I am missing a pin or something. I cant quite get the bottom bolt out because it is blocked.
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
