Calling Kinetix upper A-arm users
Old Oct 7, 2014 | 11:33 PM
  #31
bchalks's Avatar
Originally Posted by Gdirtyfive55
OK, let me be clear here because I was talking about the subframe, and I don't want you to try to tighten the comp rod ball joints to 160ft/lbs. Haha
Comp rod ball joints: tighten tight. Use best judgment. Not sure the specs.
Subframe bolts: 2 - 19mm (they may be 17mm) bolts 160ft/lbs, all other 14mm bolts I believe are 65ft/lbs
I think I know what you mean.
I tracked the car a few days after installation so I'm thinking that stress may have loosened them if that's even possible.
Old Nov 13, 2014 | 10:49 PM
  #32
NATH_19's Avatar
I have been planning to buy the kinetix a arms. I am low so i guess i will be stocck with spl or spc ??
Anyone else having problems with the kinetix hitting inner fender ??
I am just tired on spending money over tires... since my car has been a DD
n1smojunkie
Sep 7, 2015 02:42 AM
itschuckster
Jul 25, 2015 08:07 AM
