Another Grinding Noise...
Old Mar 31, 2015 | 10:48 PM
Crack3r's Avatar
I've had my coupe lowered on springs for a little over a year now and have never had a single issue with the it. But I changed my front tires (not sure if thats relevant) and basically the next day I hear a scraping/grinding noise coming from the back left wheel whenever I make hard right turns, or if I have enough weight in the car something will scrape almost no matter what. I don't hear anything when straightened out, unless there's enough weight of course and every little bump can make the grinding noise. I want to believe it is the wheel bearing, since I've taken a look at everything and the entire wheel/tire don't have any signs of rubbing. I tried using both the regular and hand brake while hearing the noise but nothing changed. The rotor looks fine, but it does have a louder grind at a certain point in every revolution. It sounds like metal on metal, however, and if I'm going fast enough the noise can turn in to a higher and higher pitch whistle. I don't want to replace the bearing if that's not the matter here, does anyone have some input? I haven't been able to find this exact problem online so here I am.
Old Apr 2, 2015 | 01:02 PM
Crack3r's Avatar
Has anyone had an issue similar to this or am I a loner here? Any suggestions or ideas are welcome
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
jjohns2711
Aug 5, 2015 08:58 AM
