sway bar install problem.. HELP
Old Feb 19, 2005 | 07:21 AM
g35noob's Avatar
i recently bought the hotchkis sway bars. after removing the sway bars and lubing the bushings, i read the next step was to put the new sway bars on but part of that included BENDING a METAL tab to allow the ends of the hotchkis to fit. how on earth do you bend this tab?
Old Feb 19, 2005 | 08:49 AM
cato's Avatar
SouthernComfort Moderator
This is why I bought the Stillen sway bars, they fit exactly. I think the tab
they refer to is on the end link. I would guess you would take a vice grip
wrench and bend it that way. Someone who has the Hotchkis will need to
confirm. I feel your pain dude! Good luck. The rear sway bar upgrade is well
worth it BTW.
Old Feb 19, 2005 | 09:15 AM
glennp_1999's Avatar
I didn't bend any metal tab to make mine fit. What metal tab are you talking about? It should be an exact fit for your car.
Old Feb 19, 2005 | 10:12 AM
1nate7's Avatar
There are full color instructions here with pics:
http://www.hotchkistuning.com/bin/in...ions/22413.pdf
I also don't remember bending the tab.
Old Feb 19, 2005 | 12:27 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
i bent a tab on both sides. vice grip does it easily. it will be self-explanatory once you get to that point and it should be included in the install instructions...
doc
Old Feb 19, 2005 | 01:38 PM
RacerX35's Avatar
It could be the metal tab on the bolt at the end link. I just rotated mine so that it fits into one of the other bolt holes in the sway bar. The spacing for the bolt holes fits just right for that tab. This is the only tab I could remember when I installed mine. Good luck.
Geez you guys were up early!
Later,
Ray
Old Feb 19, 2005 | 02:28 PM
cato's Avatar
Later,
Ray
The time stamps on this board are not realistic. I posted my earlier post this morning in the Houston area,
which is U.S. Central time zone.The time in Houston at the moment is 1:28 pm. Check out the time stuck on this post.
What is going on here?
Six hours difference!
Old Feb 19, 2005 | 02:33 PM
g4s's Avatar
g4s
you dont have to bend the end link tabs. i had my friend install mine and he followed the instructions and bent my endlinks.
a couple months down the road, i helped install racerx35's sways and we just swiveled the end link tab to fit in the adjacent hole (like he said). after doing that, i lifted my car up, took off my front sway and bent my links back to factory and installed them the same way =).
Old Feb 19, 2005 | 09:48 PM
g35noob's Avatar
thanks guys, rotating the tab made it fit perfectly. i wasnt able to notice much of a difference but then again i only did my front and i chose medium setting. ill be doing the rear tonight.
Old Feb 19, 2005 | 10:54 PM
XCELR8's Avatar
My Eibachs were really easy. Hotch says you dont have to take apart the exhaust to install theirs, but I bet you will have too.
Old Feb 20, 2005 | 03:29 AM
RacerX35's Avatar
Yeah,
g4s and I had to dismantle some of the exhaust. But it was a minor time consumer, like an extra 5-10 minutes.
Later,
Ray
Old Feb 20, 2005 | 09:16 AM
cato's Avatar
According to Q45Tech, our G35 front bar is WAY stiff and does not need
to be upgraded. It's the rear bar that makes the difference. So if you buy
both bars, set the front to the lightest setting, the rear should go medium
or stiff. I have my front at the softest setting, around 7% stiffer than stock.
My rear bar is set at the stiffest setting, around 70% stiffer than stock.
She handles great!
Old Feb 21, 2005 | 06:04 PM
g35noob's Avatar
yeah i put medium in front which i didnt really feel, but stiff in the rear which made a world of difference.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
zoop425
Mar 29, 2016 05:51 PM
linedr89
Aug 17, 2015 05:11 PM
wuppiedog
Aug 7, 2015 11:16 AM
