Handeling HELP
Old Feb 22, 2005 | 11:48 AM
Gthre35ive's Avatar
Handeling HELP
I always get great advice from this site. I need opinions on what is the best mod I can put for tight handleing when taking fast turns.
Old Feb 22, 2005 | 12:54 PM
cato's Avatar
SouthernComfort Moderator
Rear sway bar upgrade!!!! If you don't have the sport suspension, then a
suspension upgrade is called for.
Old Feb 22, 2005 | 02:30 PM
DaveB's Avatar
Tires, tires, tires. No other handling mod takes the place of a good set of summer ultra high performance tires. Period.
Old Feb 22, 2005 | 03:24 PM
Gthre35ive's Avatar
What type of sway bars and/or tires do you recommend?
Old Feb 27, 2005 | 08:01 AM
Q45tech's Avatar
Sway bar stiffness depends on what total roll couple stiffness ratios you want......which depends on the exact weight of car as driven.........driver and fuel load.
Changing the rear weight by 100 pound [full fuel to empty fuel] has dramactic effect when you get closer to neutrality........why racers have variable rear bar stiffness controls.
Same with wet vs. dry handling. What is optimum for dry will be way too much stiffness for wet.
Remember sway bars are just springs [act like springs] in parallel with vehicle body support springs [main springs]. Sway bars are not oscillation controlled by shocks which are just designed to deal with main springs. So ideally sway bars should always be half or less the main spring rate [as translated to the actual wheel rate of the combination].
Many use 10-20% stiffer springs [1" lowering] and a matching 10-20% even 30% stiffer rear bar..........netting say a 30% total rear stiffness increase [when the bar is coupled in a turn] which changes the real roll couple ratio by roughly half.
For highway tuning the oem springs are not equal to the weight distribution [54% front 46% rear stiffness] usually more like 60/40........then the stiffer [than necessary] front sway bar induces more under steer to be safe in wet conditons.
Changing total [springs plus sway bar] rear stiffness [and the ratio] by 10% can create dramatic differences in at the edge handling.
Why most sets have a stiffer front bar to negate some of the ratio changes.....a stiffer front bar fights against a stiffer rear bar. Most cars need a softer front bar to go with a stiffer rear one to help reduce front tire overload and improve tire turn in. Most cars need stroger front tires as those are the weakest link [determines the understeer ratio as the front tires exceed their load rating at the limit.
Old Feb 27, 2005 | 01:36 PM
Buddha's Avatar
i would say spending a day at the track. You will learn how to drive faster with stock setup. No mods can't help you make turns faster unless you have the skills to.
Old Feb 27, 2005 | 09:16 PM
MrBillMartin's Avatar
i second that. other than putting on some nice rubber, learn how to drive your car stock before you make any suspension changes.
Old Feb 27, 2005 | 11:00 PM
DrPJM1's Avatar
Track days and SCCA Autocross will teach you plenty. Then you will need better tires.
amart014
Apr 3, 2010 01:04 AM
amart014
Mar 25, 2010 04:23 PM
logik05se
V36 Brakes, Suspension, Wheels & Tires
Jun 5, 2007 01:33 PM
mza4
Jun 23, 2006 06:15 PM
