How do I fix a body roll issue?
Old Sep 29, 2015 | 04:12 AM
NyCrAzY's Avatar
Hey everybody,
I own a 2007 Infiniti G35 Coupe w/ Sports Suspension @ 113,000 miles and still going strong.
Here is the issue I've been having lately and its been driving me nuts ... Everytime I make a turn, my body rolls to the left or right. It has been really bugging me. What is a fix to this?
Also, at 113,000 miles, I'm still on OEM shocks. Could that be the issue? They're not leaking but perhaps they went bad? I've read online that upgrading the sway bars would fix the body roll issue, is that true?
Thank you everybody and kind regards.
Old Sep 29, 2015 | 05:07 AM
ScraggleRock's Avatar
You need new shocks. Shocks don't last 113k miles whether they're leaking or not.
You would also do yourself good to replace your lower control arm bushings and compression rod bushings (with polyurethane for best results) and you could even replace your springs, but not necessary quite yet. As far as the sway bars, yes, they help, but not on an unhealthy suspension. It's more of a performance upgrade, not a patch for body roll caused by worn parts.
Old Sep 29, 2015 | 09:32 AM
VenomGT9's Avatar
Whiteline Essentials Kit...along with the new struts/shocks
Old Sep 29, 2015 | 10:53 AM
joedaddy1's Avatar
I had the same issue.
I changed all my suspension items including shocks.
Still didn't help too much.
The biggest help was sway bar end-links.. for front and the back.. they are about $15-$25 each. I couldn't believe those things made that big of a difference. Aftermarket (non-performance) ones are thicker than OEM, and they take about 5 mins a side after you take the wheels off.
Try that..
Old Sep 29, 2015 | 01:17 PM
NyCrAzY's Avatar
Try that..
Would of never thought about changing the sway bar links ... Gonna consider that now. Any good ones you could recommend?
I'm gonna order my struts and whiteline kit later today.
Old Sep 29, 2015 | 01:34 PM
joedaddy1's Avatar
no.. since my car is fully stock, I just bought some mid-level aftermarket replacements.
BECK/ARNLEY for fronts and Moogs for the back.. I did them about 2 months ago.. so can't really comment on longevity.. but I am impressed with the improvement so far...
I was really disappointed in the lack of improvement of replacing my 120k miles OEM shocks
Old Sep 29, 2015 | 07:16 PM
What did you replace them with? I changed to the KYB excel sport suspension (mines an 04 so no sport option that year so I previously had the KYB gr-2) shocks and it made an insane difference. Like wow..I'll probably go with some 350Z koni or bilsteins next time.
Old Sep 29, 2015 | 07:29 PM
joedaddy1's Avatar
I also used KYB excel.. I could tell my suspension stiffened up, but didn't help much with sway..
With the new shocks, I could tell the car would dip less in the back during acceleration. The ride was definitely firmer than stock, which I could definitely tell.. unfortunately it stiffened up like a camaro, not a M3.. (if you've driven both cars, Camaro rides harsh and rough, while M3 rides normal until pushed)
Now with the car swinging side to side during turns, the shocks didn't do much. The sway bar end links, even with the "cheap" ones I used, made a world of difference. Now the car definitely leans much less. Enough for me to drop the tire pressure into "normal" range (36psi to 32psi) for a smoother ride.
I think during a race or auto-x the shocks would show more benefit, but the OP is complaining about "leaning" on normal everyday turns.
Old Sep 30, 2015 | 03:05 AM
NyCrAzY's Avatar
I'm trying to buy the front sway bar links ... but a lot of them say "except sports tuned suspension". Could you link me to the correct ones?
Old Sep 30, 2015 | 07:02 AM
VenomGT9's Avatar
Talk to some of the suspension vendors here before ordering.
I got a great deal from Import Parts Pro when I ordered bushings and end links, all Whiteline.
Powergrid and Whiteline make good end links but a bit more pricey than the ones mentioned above.
Old Sep 30, 2015 | 12:16 PM
Everyone swears by the whitelines, but my buddy had them on his car (different car tho - not a G) and they busted in like 3 months. He's had better results with the Moog.
Old Sep 30, 2015 | 01:52 PM
VenomGT9's Avatar
Had mine over a year now, no issues to report front or rear
Old Sep 30, 2015 | 02:16 PM
gary c's Avatar
KYB shocks will give you a new car ride and feel and the cost won't drain your wallet! If this is something that you just began to feel the KYBs should take care of the body roll you're experiencing. Next step if you intend to play in the twisties w/b fatter sway bars and adjustable endlinks, Grid Power makes the best endlinks...fact!
Gary
Old Oct 1, 2015 | 09:19 AM
joedaddy1's Avatar
no link sorry.. haha
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
apintojr
Jul 23, 2015 10:52 AM
