Stoptech pads and rotors
Old Oct 4, 2015 | 08:54 PM
dpark0223's Avatar
Just installed new rotors and pads from stoptech. Its been making vibrating noise when i press the brake slighty going to a slow full stop. Sort of feels sticky. Any solutions? I had it on for four days. It started ever since i put the pads on.
Old Oct 4, 2015 | 09:01 PM
Blue Dream's Avatar
I drove ttrank's car solo
Did you properly bed in the pads after installation? If not then do that asap. Also make sure your lug nuts are all tight.
Old Oct 4, 2015 | 10:22 PM
faiz23's Avatar
Are they slotted or drilled/slotted?
Old Oct 4, 2015 | 11:28 PM
dpark0223's Avatar
i told my girlfriend to do it because we went to go pick up the G with my girlfriends car, so we dont have to take the taxi. i told my girl what to do.. so maybe she messed it up? anyway i did it again today. 3 - 35mph to 5mph with moderate braking. 3 - 45 mph to 5mph with moderate braking and parked my car. So, i hope it works out.
Old Oct 5, 2015 | 08:59 PM
dpark0223's Avatar
Its still vibrates/stutters like braking after getting a carwash. I did the bed in process. Any more solutions?
Old Oct 6, 2015 | 12:25 PM
spitfingers's Avatar
I know every case is different, but after i did my pads and rotors i had that happen also even after bed it. I ended up just changing the shims and cleaned/greased the sliding pins and it went away.
Old Oct 6, 2015 | 12:28 PM
dpark0223's Avatar
Where do you buy the spare parts and sliding pins? What are they. Im new to the g
Old Oct 6, 2015 | 12:33 PM
I have an 05 G35x and I went to pepboys, since its down the street. Rockauto may have been cheaper but it was annoying.
http://www.pepboys.com/product/details/9945988/00363
got that and some grease. after this and cleaning the pins it went away for me.
Old Oct 6, 2015 | 12:35 PM
dpark0223's Avatar
and is there a diy for installing these?
What kind of grease? Wheres the pins?
Old Oct 6, 2015 | 12:40 PM
I went with cheap brake grease that was like $8, when it comes to the pins its easier if you look at the service manual. Im at work so later i can put up a pic of it with the pins circled unless someone else does. I dont remember if i got it on her or the nico forum, but it is posted and really helps.
Old Oct 6, 2015 | 12:45 PM
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/br.pdf
Old Oct 6, 2015 | 12:46 PM
dpark0223's Avatar
In order to replace the shims, i have to take out the pads?
Old Oct 6, 2015 | 12:55 PM
Take a look at what I just put up, but yes the pads come out for a moment. I think I did this to both front brakes in 30-45 minutes. If you changed the pads and rotors this is the same steps but less since you dont need to take the whole caliper off.
Old Oct 6, 2015 | 12:57 PM
dpark0223's Avatar
Thanks ill try it this weekend and let you know wht happens
Old Oct 6, 2015 | 12:58 PM
dpark0223's Avatar
And also do i put brake grease on the shims too? Or jsut the pins
