2003 6MT coupe on 350z Bilstein/Pro-Kit
Old Nov 25, 2015 | 04:56 PM
EPiK's Avatar
Initial impression.. PERFECT.
I bought my car with D2 RS true coilovers on it. A lot of tuning later, and I had them daily driveable, but the high spring rate since they are designed to go LOW had them crashing on bumps and bridge joints way too much for my comfort.
With some careful Ebay shopping I scored a set of very low mileage used Bilsteins from a 2008 350z..like half price for 5 months worth of use. Perfect for my budget with this car. The seller even hooked me up with the stock upper mounts which I didn't have with the D2s.
My research on ride quality and drop led me to buy a set of 350z Eibach Pro-Kit springs next..new at $250 shipped.
It all came together here the other day, I assembled them and ran out of daylight, so it was on for the next day.
The coilovers were off, pics taken and posted for sale, and the Bilstein/Eibach setup was on in just over an hour..
The drop on the Bilstein/Eibach after an "exuberant" 5 mile test drive is identical to where I was sitting for height on the D2. I know it will settle a bit over the coming weeks and that's fine with me.. exactly what I wanted.
Car is sitting at 25 1/2" at all 4 corners from the fender lip to the ground. I'm on 18" wheels, 235/40 front and 275/35 rear. I love the stance of the car, knowing it is a functional drop..no not "stanced" I have full contact patch. or very near full.
Riding at that height for the last few thousand miles I have no camber wear issues. I'll keep an eye on it and adjust/buy/align as necessary.
typing this on the laptop and adding pics off my phone later. so follow along..
The box they came in. .lol
Old Nov 25, 2015 | 05:12 PM
EPiK's Avatar
I just checked the drop again in the driveway after a 40 mile round trip to and from work last night.. no change, 25 1/2" all around.
pics..
Old Nov 25, 2015 | 05:20 PM
EPiK's Avatar
on another note.. definitely going up to 25 mm spacers on the front as well.. 15mm right now.
Old Nov 25, 2015 | 05:34 PM
Lartytiejdke3's Avatar
What's the spec up front
Old Nov 25, 2015 | 05:42 PM
EPiK's Avatar
Volks? Supra fitment. Front 18x9 +43, 235/40/18 15mm spacer, Rear 18x10 +44, 275/35/18 +25mm
I'm going with fatter tires once these Riken Raptor wear out. They were brand new (dyno break in miles) when I bought the wheels.
Old Nov 29, 2015 | 08:53 PM
EPiK's Avatar
Few hundred miles in and still loving this combo. Will take some measurements tomorrow to see if it settled any more.
Old Nov 30, 2015 | 01:29 AM
Tyke420's Avatar
If you already do not have a rear camber kit with toe bolts, I'd definitely keep an eye on rear camber wear.. It's hard too tell with the wheels on your car... But pay close attention to that and take a tire off and examine it... Safety first...
Old Nov 30, 2015 | 01:52 AM
EPiK's Avatar
I'm keeping a close eye on it, checking tread depth by gauge, much better than eyeballing it
Old Nov 30, 2015 | 01:57 AM
Tyke420's Avatar
Some of us do not agree with the toe bolt upgrade.(dremel the toe bolt location for more adjustability)But by all means I'd just do it so the alignment tech can get it perfect...
Old Nov 30, 2015 | 01:58 AM
EPiK's Avatar
What is it, just an eccentric bolt and washer?
Old Nov 30, 2015 | 01:59 AM
ScraggleRock's Avatar
Originally Posted by Tyke420
Some of us do not agree with the toe bolt upgrade.. But by all means I'd just do it so the alignment tech can get it perfect...
Toe bolts are the most necessary mod when lowered. $27 and a couple hours under the car will save you a ton of money on tires.
Old Nov 30, 2015 | 02:00 AM
EPiK's Avatar
I'll pick up a set before I head to alignment. Planning it soon anyway
Old Nov 30, 2015 | 02:01 AM
It's a bolt with eccentric cam washer and a stencil you trace and then drill out with a carbide bit. Basically you enlongate the hole that the toe bolt/spring bucket sit in, and you get the eccentric bolt and cam washer.
Old Nov 30, 2015 | 02:06 AM
EPiK's Avatar
Sounds easier than my past z3 race car. To get rear camber and toe adjustment you had to weld plates to the trailing arm brackets in order to use oem e38 eccentrics.
Old Nov 30, 2015 | 02:07 AM
EPiK's Avatar
Who sells this kit?
