sport tunes suspension
Old Mar 7, 2016 | 10:56 AM
robert1911's Avatar
Ok so my car has the sps package however it is now comming up on 129k miles and i would like to replace some of the parts that came with this package.
Where should i start? I know the sway bars were stiffer but what else is included?
Also what would you recommend i upgrade to for better handeling on the street (with maybe some light track intentions). I still want a smooth enough ride.
Old Mar 7, 2016 | 03:36 PM
G35fromPA's Avatar
Do some searching. Sport suspension had stiffer rear springs, stiffer sway bars and the 19" wheel/tire combo.
At 129K, likely you'll want to replace all the front bushings (LCA, compression rod, UCA, sway bar) plus possibly some of the rear bushings - whitelines are good choice.
Likely your shocks are done - If you don't want to go the coilover route, Koni Yellows, Tokico DSP, and Bilstein are good options if you want adjustability.
Springs could be sagging a bit, but those do last a while.
You could add adjustable sways (Stillen, Motordyne, etc.) if you want to tune for the track and/or go stiffer for the street. Will still yield a nice ride as a DD
Also look at the stickies at the top of this section.
gprabhu
Steering & Suspension
Aug 18, 2016 04:47 PM
edwinisdumb15
SOCAL Meetings & Events
Feb 7, 2016 09:57 AM
John_R
Dec 16, 2015 07:35 AM
dc2long
Dec 14, 2015 12:28 AM
