2003 g35 revised compression rod question
Old Mar 7, 2016 | 12:34 AM
VincenzG35's Avatar
What exactly was revised and anyone have the part number for the sedan all the posts explaining it have 10 other part numbers and i dont wanna make a mistake
Old Mar 7, 2016 | 05:17 PM
VincenzG35's Avatar
Can anyone help i just wanna order the part
Old Mar 7, 2016 | 05:28 PM
ScraggleRock's Avatar
The bushings were not revised til 05. You are better off replacing just the bushings with polyurethane bushings.
Old Mar 8, 2016 | 09:12 AM
LoSt180's Avatar
There's a TSB (technical service bulletin) with the correct part number listed. Use that part number, you can't make a mistake.
Old Mar 8, 2016 | 11:03 AM
LoSt180's Avatar
Update: you want part number 54570-AC70A
CZP has it available here: https://conceptzperformance.com/infi...70a_p_6037.php
Old Mar 8, 2016 | 01:50 PM
infinitidude's Avatar
54570-AC70A if it is a rear wheel drive. If you have an X model the number is 54570-AC71A
Old Mar 8, 2016 | 04:00 PM
NemesisGee's Avatar
So you no longer have to replace the entire compression rod? Relatively new owner, read some threads where the whole rod was replaced that included the ball joint.
Old Mar 8, 2016 | 04:46 PM
At the age of the car, it's better to replace the whole rod so you can have the new ball joint too. If you inspect the ball joint and it's good then it's OK to just replace the bushing. If you need a new ball joint tho, you have to replace the whole arm.
Old Mar 8, 2016 | 09:26 PM
NemesisGee's Avatar
Thanks good to know for future reference. And what about the aftermarket rods? The Dorman's whole arm and B-joint they sell @ Rock Auto are pretty reasonably priced. Are they any good? Anyone can suggest an cheaper alternative to OEM?
Old Mar 8, 2016 | 09:38 PM
I used to sell the mevotechs. No idea how the bushings held up cuz I would replace them with poly before installing, but it's just cast aluminium like OEM, so it's fine. The ball joint in that position is pretty passive, so it's not enduring a ton of abuse. The bushing really is the biggest area of concern. Factory camber angle just tears rubber up..even the revised ones are known to breakdown.
sumptimwong
Mar 4, 2016 04:58 PM
ATLIAN
Mar 1, 2016 05:52 PM
johnunderkofler
Feb 17, 2016 04:38 AM
Gdup35sedan
Feb 16, 2016 01:19 PM
