Another curb hit
Old Apr 5, 2016 | 03:03 PM
kinetek's Avatar
Angry Another curb hit
Hello again,
Due to shitty weather I hit the curb yesterday (and yep, VDC on and no drifting on G35x). I was going around 20mph on a steep road and didn't manage to turn which was a surprise for me as (I think impact speed was around 5-10mph), I was just going forward and what I managed to do is to turn the car parallel to the curb and first I slightly hit the curb with my front wheel (which seem fine and I hope it actually is) but the main impact happened to the rear wheel. The tire didn't blow and the rim doesn't look bent so I managed to drive home with VDC/SLIP lights on and wheel turned to the right because my rear wheel is "slightly" out of alignment. I jacked up the car, removed the tire and found only one bent piece which is part number 551A0-AL500 (what's the other name of it btw?). I already checked if I can remove the lugs and my result seem positive so I ordered the OEM part and will try to install it asap and then do the alignment, however, I'd also like to check if you think anything else could be damaged here as well?
Thanks.
P.S. And yes, the tires are bridgestone potenza on 17" rims. If I had goodyear ultra grip winter like I had on my TSX I wouldn't be posting this.
Old Apr 5, 2016 | 04:11 PM
juancuellar14's Avatar
Unhappy
OUCH
Old Apr 5, 2016 | 04:26 PM
JOKER's Avatar
CLUB MODERATOR
I'ts a camber arm
It's a weak piece of tubing in the suspension that bends with any side impact. Which is kind of good because it prevents any other suspension component from damaging
Do a search on ebay, there are plenty of used for a good price, no need to order new one from dealer.
Old Apr 5, 2016 | 04:44 PM
kinetek's Avatar
СпасибоУже заказал себе за 35$ БУ OEM. Очень надеюсь, что это таки оно. По результатам отпишусь. На английском.
Old Apr 5, 2016 | 09:19 PM
YOTA's Avatar
Is that the rear camber arm? You can choose to upgrade it to an aftermarket set if it is which are typically better and give a wider ranger of adjustment.
Old Apr 6, 2016 | 11:41 AM
kinetek's Avatar
Probably it is, although I've seen different names for this part. Honestly, I don't care about aftermarket parts, I just want my babe back
BTW, I wonder, maybe it would be better for me to jump onto the curb with two front tires? What do you think?
Old Apr 6, 2016 | 12:58 PM
hurleyguys's Avatar
not sure what you are asking but go big and jump on all 4.
Old Apr 6, 2016 | 01:16 PM
kinetek's Avatar
I'm asking if there was any sense to hit the car like that: first front left wheel a bit, and then rear wheel with bigger impact, instead of that I could've hit the front left wheel and then front right wheel, i.e. direct impact instead of parallel one because initially I was going straight to the curb Maybe I didn't have any damage if I just hit the curb straight?
Old Apr 6, 2016 | 06:18 PM
JOKER's Avatar
CLUB MODERATOR
Get the alignment done afterwards ASAP.
Old Apr 6, 2016 | 10:09 PM
kinetek's Avatar
I guess I have no other choice.
I've been researching tires and my tires are on the last place here: http://www.tirerack.com/tires/survey...earDiameter=17 What can I say? Maybe I'm lucky that didn't jump off the cliff because of them? That would be lotta fun. I'm changing this piece of this and throwing them out as soon as my car is back on the orad.
Old Apr 6, 2016 | 10:41 PM
Justice06RR's Avatar
He's asking if it would've been better to hit the curb going straight, and have the front 2 tires take the hit.
That's actually worse IMO because it could've damaged your front bumper, screwed front alignment and suspension, and possibly mess up the undercarriage if you went over the curb.
Would be worse if there was a cliff past the curb
Old Apr 9, 2016 | 07:37 PM
kinetek's Avatar
Did the job today, took me roughly 1.5 hours, the lights are now gone and the wheel is straight. Lessons learnt.
Old Apr 14, 2016 | 12:27 AM
JOKER's Avatar
CLUB MODERATOR
Drift on!
08STLX
Feb 5, 2016 01:44 PM
jayd33-
Feb 1, 2016 10:39 AM
jayd33-
Jan 30, 2016 03:12 PM
saywat?
Lights
Jan 29, 2016 01:55 AM
Calipat916
Jan 14, 2016 02:43 PM
