super bouncy harsh ride g35 sedan new struts just installed
Old Apr 16, 2016 | 09:43 PM
ninjabong's Avatar
so I have new struts installed kyb and that is all I have done to the suspension just bought the 05 sedan with 122k miles and it does do the creaking over small bumps and low speeds and especially when also turning so thats the compression rod I'm sure. and I can see grease on the differential from behind the car underneath so I know the diff needs new bushings so I bought this set of whiteline bushings
http://www.autoanything.com/suspensi...3A3970045.aspx
http://www.whiteline.com.au/product_..._number=WEK003
I'm wondering how many hours all this should take to install.
so I know the differential bushings take about 4 hours?
and I think the compression rod bushings are going to be about 8 hours for both sides? is that right? from what I've seen on the forums most people paid about 800$ for both sides new bushings installed.
and then the control arm bushings I am not sure how long those take I'm going to keep searching for an answer if anyone can help out that would be great thanks.
and then
Old Apr 22, 2016 | 10:09 AM
nizzan4u2nv's Avatar
and then
No way it should take 8 hours. I did inner/outer lca bushings and compression rod bushings by myself in 3-4 while taking my time. My harbor freight press paid for itself after its first use. Differential bushing I have yet to do, but does look like a bitch. More so for sedans since theres less space because of the spare well.
Old Apr 22, 2016 | 11:52 AM
ninjabong's Avatar
thanks for the reply. it's been difficult finding a shop near me that wants to do the work. I'd do it myself but have no space for that. I'm an apartment dweller. I think I finally found a shop that will do it but they want to do an 150$ inspection first I figure might as well most shops are probably going to do that.
EricB
Oct 24, 2011 02:12 PM
AmeRikaZmoStWaNteD
Aug 5, 2011 03:44 AM
VxLyf3
May 9, 2010 11:24 AM
VxLyf3
May 1, 2010 07:37 PM
DG_coupe
Dec 11, 2008 03:31 PM
