Axle nut keeps coming loose
Old Feb 16, 2018 | 07:38 PM
YoungGuwap's Avatar
I recently replaced my rear wheel bearing on my 2004 g35 coupe. The issue is the axle nut keeps coming loose. I retighten 4 times already no luck. Any help?
Old Feb 16, 2018 | 07:43 PM
gmotion04's Avatar
Did you add locktite? Did you torque it to manufacturer specs?
Old Feb 16, 2018 | 11:48 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like two issues, firstly not torqueing to the manufacturer required 152-202 ft/lbs, secondly not adding the cotter pin...
Old Feb 17, 2018 | 12:00 AM
gmotion04's Avatar
Yeah, that was my next question.
Old Feb 17, 2018 | 11:50 AM
cleric670's Avatar
BANNED!!!
I wouldn't loctite the thing either, that will just make it a total pain to get off the next time.
Old Feb 18, 2018 | 03:40 AM
YoungGuwap's Avatar
Well I took everything apart and cleaned it all up. Added some blue loctite, and torqued it to specs. So far so good.
Old Feb 18, 2018 | 12:24 PM
cleric670's Avatar
BANNED!!!
What about the cotter pin? The reason for the variable torque is you start at 150 ft/lbs then rotate it to the NEXT opening for the cotter pin. That nut will probably be a nightmare to take off next time from that loctite.
EDIT: Sometimes they use a SINGLE USE nut that will have this "sleeve" on the trailing end that is slightly smaller diameter and will squeeze over the shaft as you tighten the nut. OEM shafts and most aftermarket ones use a cotter pin for nut retention though.
Old Feb 19, 2018 | 08:10 AM
YoungGuwap's Avatar
Well I thought my issue was over, but after driving today I heard a noise jacked it up and it was becoming loose again. I tried everything, but putting a new nut on. Could've I gotten a bad wheel bearing?
Old Feb 19, 2018 | 08:12 AM
YoungGuwap's Avatar
The cotter pin doesn't go against the nut. the hole is far away from it.
Old Feb 19, 2018 | 08:35 AM
cleric670's Avatar
BANNED!!!
How many lbs are you torqueing it to? Is your torque wrench failing and not accurately putting 150# on the nut?
Did you use a cotter pin to retain the nut?
If it doesn't have a cotter pin are you using a NEW sleeved nut every time you take it off?
I suspect either you are trying to guess the torque instead of measuring it with a wrench, I also suspect you're not using the cotter pin. Never in my.life have I seen a properly installed drive axle come loose, especially multiple times.
It might be time to take it in to a mechanic since this is pretty serious and can lead to further damage of the vehicle.
Old Feb 19, 2018 | 08:40 AM
cleric670's Avatar
BANNED!!!
Order new nuts, you might have bad ones?
https://www.z1motorsports.com/rear-hub-and-rotor/nissan/oem-rear-axle-nut-350z-g35-p-9196.html
Also, there is a TSB that supersedes the FSM and axle nut torque is now 175 ft/lbs.
Old Feb 19, 2018 | 08:46 AM
YoungGuwap's Avatar
Yes I have a proper torque ratchet, yes in using a cotter pin. I have a new nut that I haventh tried installing because I didn't know that could actually help. I did the other side too, and the nut never came loose which is why I'm so confused.
Old Feb 19, 2018 | 08:48 AM
cleric670's Avatar
BANNED!!!
Is the old nut that giving you problems a flanged nut like the one shown in the picture?
You should also pull the axle back toward the differential and make sure there isn't any debris on the back of the hub.
Old Feb 19, 2018 | 08:58 AM
YoungGuwap's Avatar
Yeah. It's the same type of nut. I already pulled everything and cleaned it last time before retighten the nut, and it still came loose.
Old Feb 22, 2018 | 04:24 PM
TurboRev's Avatar
+1 all day, you just need a new one. I always use a brand new one after having to do any kind of axle work; and they're only a couple bucks so it's easy on the bank.
