Front suspension rebuild suggestions
Old Mar 28, 2018 | 12:23 PM
cswlightning's Avatar
Hi all,
I've amassed a collection of suspension parts to install to give my 125k mile Maine daily driven coupe that factory fresh steering feel and ride as well as give me a solid platform to build on in the future when the G is relieved from its daily slog to work and back.
My goal is to do this and not touch the front suspension ever again aside from maybe brakes, bearings, and end links if needed.
Parts that will be in my front susp. after the latest round of work:
Whiteline poly LCA, comp rod, UCA bushings
Energy poly steering rack bushings, sway bar bushings
KYB struts
350z front springs (if I can find 'em cheap)
MOOG strut mounts
MOOG tie rods, inner and outer
Mevotech Premium lower balljoints
After all of this the only not-new parts in my front suspension will be:
Original 125k mile UCA ball joint
Compression rod ball joints (PO seems to have replaced comp rods, but bushings are cracked)
Both of these components appear "good" but they've clearly been on the car for many years.
How often do these non replaceable ball joints in the UCA and comp rod fail? Would it benefit me to install some low mile used upper control arms along with the rest of this stuff to remove that last 14 year old component "while I'm in there" so my front suspension has a better chance of staying tight for the next 100k miles or so?
Old Mar 28, 2018 | 05:26 PM
LoSt180's Avatar
Just get new Mevotech arms from rock auto and not worry about it again. I replaced everything you listed, then some, when my car got to 200k. It had some creeks and pops so I just threw parts at it, lol.
Old Mar 28, 2018 | 05:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you're getting the 350Z springs in the front get adjustable FUCA because it will lower your front 1/2" and camber will be off.
Old Mar 29, 2018 | 02:16 PM
Looks like I'll be keeping stock springs and doing the spring mount mod in the back where I have a camber kit.
I'm going to keep rolling on the stock ucas for now as i had no idea that they were so easy to swap out.
Thanks for the input guys!
BigtomG
Jul 30, 2021 09:52 AM
ChrisAult2004
Mar 31, 2017 10:20 PM
ILCruisin2006
Dec 14, 2016 06:52 PM
Skippedcollege
Oct 25, 2016 06:38 AM
vrracing
Jan 8, 2016 01:19 AM
