Lowering coupe
Old Apr 21, 2018 | 03:39 AM
Sean McCants's Avatar
Lowering coupe
I've been looking to lower my coupe it's a 05 I'm pretty sure I want 350z springs on it but I don't know if I also need 350z shocks and a camber kit since it's not too low, also people have said they can get them for 50 but I've only seen 150 can yall help me
Old Apr 21, 2018 | 09:38 AM
gary c's Avatar
Use our SEARCH, this question has been answered a gazillion times! Gary
Old Apr 21, 2018 | 11:07 AM
So helpful I read through about 4 posts this is all I could figure out
Old Apr 21, 2018 | 11:36 AM
herrschaft's Avatar
You won't need to replace shocks, but a camber kit might be needed. Should be a small drop so get an alignment first to see if you need the camber kits.
Old Apr 21, 2018 | 12:49 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I just checked an old alignment report and when I initially put pink dot front springs on I was sitting at -1.8 degrees camber on the front. Trimming the rear spring perch rubber the additional 1/2" to match the front put me at -2.0 degrees camber rear. Every vehicle is slightly different though so your mileage may vary.
Old Apr 21, 2018 | 02:48 PM
gary c's Avatar
You didn't ask the right questions...Gary
jww
Jun 7, 2007 01:32 PM
Kilrmy
Sep 7, 2005 10:51 PM
minhjle
Sep 22, 2003 06:17 PM
englishguy
Aug 22, 2003 10:24 PM
Kilrmy
Jan 23, 2003 11:16 AM
