hex bolt
Old Jan 14, 2019 | 01:13 PM
poppamalu's Avatar
g35S
hex bolt
i was wondering if you could help me with the measurements of my bolt, the top bolt on my caliper is a regular bolt that can be removed with a 13mm socket but the bottom bolt for both driver and passenger (front) has a bolt with a hex shape indention and im trying to figure out whats the measurement of the hex indention so that i can get the part
Old Jan 14, 2019 | 03:04 PM
MooseLucifer's Avatar
5 Year Member
blk
Are you talking about your brake caliper? Pics would go a long way here, when you say 'hex indention' do you mean a socket cap bolt that you'd remove with an allen key?
Old Jan 14, 2019 | 03:08 PM
poppamalu's Avatar
g35S
yes one of the brake caliper bolts looks as if you need a hex key to remove it
Old Jan 14, 2019 | 03:09 PM
poppamalu's Avatar
g35S
or allen key whichever it called
Old Jan 14, 2019 | 04:08 PM
telcoman's Avatar
Veteran: Army
Go to Harbor Freight and purchase a complete set
Telcoman
Old Jan 14, 2019 | 04:52 PM
5 Year Member
blk
Are you on OE Brembos? If so, the entire caliper is powder coated after assembly, meaning no standard allen key will fit that socket head cap without stripping the coating off the socket cap section of the bolt (or stripping the bolt itself, or stripping your harbor freight chinesium alloy allen key).
Also, if it's OE Brembos you're talking about, I'd reconsider cracking those blocks open, or you may find yourself looking for a new internal crossover fluid seal that does not exist as a standalone replacement part. You can pretty easily find small Ø high temp o-rings, but... well it's your call if you want to risk it!
g35xdriver4life
Apr 10, 2019 09:41 PM
jackhunt3r
20 Inch
Jan 10, 2019 05:55 PM
JG_G35
Steering & Suspension
Jan 9, 2019 02:07 PM
g35xdriver4life
Jan 7, 2019 07:11 PM
