Brake Line Fittings ?
Plan on doing some brake line replacements in the future but would like some info on what type of fittings the 2005 RWD G35 uses?
I've measured the lines to be 3/16ths to the calipers and 1/4 from the Master... but are the lines Bubble flared or Double flared? I'm assuming the fittings are metric?
Thanks for any help
Thanks for any help
Is there a reason you're not going with lines that are sold as a package? Ss braided lines from stop tech are about $135 for all 4 corners. I may be misunderstanding what you're trying to do though. I'm just assuming your replacing the rubber lines.
Long story short I've got a 2004 Master Cylinder with Brake Booster cheap and I'm thinking I might swap out the stock 2005 Master and Booster ... the issue is the brake lines hook up on opposite sides of the Master cylinder.
I might have to disassemble a line and see what I've got.... I'm guessing a double flare with a metric fitting.
mliu66
May 28, 2014 02:10 PM
grocerylist
May 14, 2012 08:14 PM
BrianV
Oct 20, 2005 01:42 PM
