brake fluid sensor replacement
Old Dec 20, 2019 | 04:58 PM
jeffberk1's Avatar
G35x
I'm having a problem, possibly related to the brake fluid level sensor which I'm trying to replace.
Is there a way of removing the sensor without removing the master cylinder? It appears to be held in place by plastic tab but there doesn't seem to be a way of pulling the sensor out after it's been pushed into place.
The photo shows the sensor with the connector removed, looking up from under the master cylinder.
G35 2008 with AWD
Jeff
Brake fluid level sensor
Old Dec 26, 2019 | 12:22 PM
Abdul Kelani's Avatar
G35 coupe
na those are usually built in to the reservoir, if theres an issue you replace the entire thing
Old Dec 28, 2019 | 01:30 PM
jeffberk1's Avatar
G35x
I was eventually able to remove the old sensor by feeling around and jamming in a small flat screwdriver to release the clip. The new sensor seems to have solved the problem however, I have no idea how it works. I've never seen a non-contact brake fluid sensor or even one without a float before.
infinity35
Aug 21, 2019 10:39 AM
Matthew Crowe
Aug 17, 2019 09:48 AM
Chris's g35x
Feb 6, 2018 12:11 PM
kwiniarz
Apr 15, 2009 02:24 PM
dklau33
Aug 28, 2006 02:30 PM
