03 g35 handbrake light doesn’t engage
Old Oct 25, 2020 | 04:45 PM
Ryan007's Avatar
2003 Infiniti G35. Motordyne Catback exhaust. Skunk2 Plenum spacer. JWT popcharger. JWT clutch/FW
Hello. So I started my car after a while. And noticed that my “brake” light doesn’t come on when the e brake is engaged. Did numerous searching but only found those whose light stays on. Any input will be appreciated. Thanks. Also I know it isn’t the bulb because it does illuminate it I put the key into the “on” position and e brake does hold the car so it is functional. But why doesn’t it show up on dash?....
Old Oct 26, 2020 | 10:09 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
There is a e-brake switch that contacts the handle (6mt) or pedal (5at). If that switch is stuck closed, I think that would explain why the light doesn't come on.
With my '04 G, even if I barely touch the e-brake pedal, the light on the dash will illuminate FYI
Old Oct 26, 2020 | 10:55 AM
Ryan007's Avatar
Thanks! I will check it out. It’s a 6MT.
Old May 23, 2023 | 02:56 AM
Ryan007's Avatar
where is the switch?
daffy12
Jul 8, 2012 01:35 AM
hotdamn
Lights
Jul 14, 2011 03:29 PM
Fri Guy
Jan 18, 2008 08:28 PM
