Megan Racing UCA Camber
Old Feb 9, 2022 | 12:41 PM
RARA's Avatar
G35 Sedan 6 Speed
Hey everyone,
I just got these new UCAs on my car and I'm on Tein Basics. I just noticed that with the control adjusted all the way out (less camber/+) I'm getting -2.6 and -1.8 in the front. My inner lower control arm and compression rod bushings need to be replaced. Is this the cause of the unevenness? How is this even possible? Do I need to get different control arms? Or can I just raise the ride height of my car? Please let me know your thoughts.
Old Feb 11, 2022 | 08:41 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Possibly, that's quite a bit of difference between the two sides.
Lowering the vehicle will always cause negative camber so if you raise it then yes you will add positive camber.
Old Feb 16, 2022 | 07:02 PM
RARA's Avatar
G35 Sedan 6 Speed
If I don't plan on raising my ride height, then I'll most likely have to get new upper control arms right? I looked up the Megan Racing ones, and they say that they can only adjust negative camber only. They don't even say a specified range.
