Need help to verify figment of coilovers
Old Jun 29, 2022 | 06:45 PM
Boanz's Avatar
G35X sedan
Hello all first off I have a 07 g35x i did try the search but I didn’t find a answer I am looking at a set of Megan racing coilovers ez2 series they are on Facebook new unopened the box says they are for 03-06 awd when I look them
up on line they are list for 03-08 awd my question is will they fit recently I was at junkyard looking for used struts but no luck but while i was there I looked at a 06 x model and the only real difference I saw was the mount bracket for the brake line and sensor wire but the strut in general looked the same can someone verify this for me ty I hope I posted in correct spot any help would be greatly appreciated
Old Jul 2, 2022 | 07:35 PM
Boanz's Avatar
G35X sedan
They do fit
Ok to anyone that may be wondering I did pick up the coilovers and they fit with almost no issues so on the fronts the only issue was the bracket for brake line and sensor wire are a bit different you just have to adjust it so the sensor wire bracket on knuckle clears bracket on coilover that’s only issue I found there is also plenty of adjustment up and down for the rears the issue is the strut is about 1.5”-2” shorter so not much adjustment up but plenty down which was fine for me I liked where they sat and I had to drill holes for damper adjusters other then that they rode great on my test drive no rubbing in rear and camber is still pretty good I do still have to drop the about 1.5”-2” to match rear I will report back after I get some real drive time on them hope this helps someone somewhere somehow ty
yosip1115
Steering & Suspension
May 24, 2016 02:21 PM
reavensf
Sep 17, 2015 11:30 PM
Gtz1stballer92
13
May 1, 2012 04:26 PM
FlyingLumpia
V36 Brakes, Suspension, Wheels & Tires
153
Apr 16, 2010 11:23 AM
