Brembo Rear Brakes And Rotors $1,400.00
Old Jun 22, 2005 | 06:56 PM
GYAL8R's Avatar
Cali Event Coordinator
BASE ACURA TLX NOW WANT A G35 AGAIN THOUGH
Does this sound right?
There was no warning or grinding noises until Monday.
Took it to Peninsual Infiniti...said it's down to metal-to-metal...original estimate was $70.00 to inspect and $400.00.
Now they tell me I'm looking at $1,444.00 just for the f'n rear brakes...!!!
I'm "FURIOURS"...WTF...???
Should it cost this much to replace them at only 24,000miles?
I've already replaced the front brakes that was under $500.00!
GEEEEEEZUS...!
BoBs - San Francisco
Old Jun 22, 2005 | 09:25 PM
G35fromPA's Avatar
What are they installing, gold plated rotors? I'd say that sounds outrageous, considering you can get Stoptech Aerorotors for $836. What is the itemized estimate (parts and labor) they're giving you?
FYI - You can get new pads and rotors for a lot cheaper:
Brake Pros Rear Rotors ($437/pair):
http://performancenissanparts.com/ca...roducts_id=363
OEM Brembo pads ($95.50):
http://performancenissanparts.com/ca...roducts_id=350
I'd say, at $1400, that's a heck of a lot of labor!
Old Jun 22, 2005 | 09:47 PM
GZire's Avatar
If it's rotors and pads, I'm with G35fromPA, the cost is too much.
Are they throwing something else in like other servicing, replacement of pads, alignment?
Old Jun 22, 2005 | 10:19 PM
Balzac72's Avatar
G SQUAD
Damage to the caliper pistons maybe? Could be a piston rebuild?
Old Jun 23, 2005 | 12:08 AM
G352NV's Avatar
Never enough
I just replaced all four with slotted and drilled with dust free pads for 550.00
Old Jun 23, 2005 | 12:35 AM
GYAL8R's Avatar
I'm supposed to pick the car up tomorrow.
They had to fix my emerceny signal button was part of it like $70.00
I'm going to itemize everything and b***h like hell.
That's 2 car payments / mortgage for BREMBO REAR'S?
You'd think that BREMBO would state on the MSRP "be ready to pay $1,500.00 @ 24K it's not covered under INIFNITI warranty.
I'm I the only one pissed about this?
If there isn't a campaign from BREMBO owners to try and have BREMBO pay for this "DEFECT" as I call it, I'll start it and hopefully they'll hear us...
BoBs
Old Jun 23, 2005 | 01:29 AM
G35_Foo's Avatar
damn hope you get this figured out
Old Jun 23, 2005 | 04:10 AM
GYAL8R's Avatar
i'm hoping there was an error when he added up the parts and labor...
i swear infiniti hq is gonna hear about this one.
Old Jun 23, 2005 | 06:04 AM
ChuckP's Avatar
get some slotted/drilled rotors like g352nv did for 400, some hawk hps pads for 150, a 12er of some nice brew and a day for install
Old Jun 24, 2005 | 07:08 PM
GYAL8R's Avatar
So here's what "PENINSULA INFINITI" told me...
1) They were able to "SAVE THE ROTORS" for now. It's currently at 2.5mm and recommend to change before it gets to 2.2mm - I told them not to do it. The pads for the rears came out to a little under $400.00 which is fine since they had to fix my hazard lights $70.00 labor.
My thoughts:
There was no warning or squeeking noises from the rears at all...!
$1,000.00 + for any brake job is "RIDICULOUS" and that's just for the rears!
Isn't the optional BREMBO package only $2,000.00 with the car new from the factory?
They said I must've been "SLAMMING HARD" on my brakes...i'm like that's BS I down-shift more than slam on the brakes..!
My Question is this:
How many months or miles do I have left before I "MUST" change my rotors? Again it's at 2.5mm....recommend to change by 2.2mm. I'm going to switch to slotted rotorz and I'm going to check with ZCARGARAGE..
Is the $400 for both rear rotors or each?
Thanks for your help guys!
BoBs
Old Jun 24, 2005 | 07:27 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
****...pay me and I'll do the rotors and pad replacement for you
vinh
Old Jun 24, 2005 | 09:18 PM
ChuckP's Avatar
400 for all 4 bro
Old Jun 25, 2005 | 07:34 AM
G35fromPA's Avatar
Again, with pads at around $100 for the rears, what the heck does the $300 for labor get you? A pad change is 45 minutes, tops. That should be less than $100.
Even if you had been "slamming hard" on your brakes, the front brakes would be doing most of the work, due to weight transfer under braking. The rears only do 15-30% of the braking, so they would not wear out that fast. Also, for future reference, it's not a good idea to slow the car down with the transmission. It will wear out your clutch and gears a lot faster, and those are still much more expensive than your pads and rotors.
Good luck!
Old Jun 25, 2005 | 04:44 PM
marchesano's Avatar
www.g35tt.com
G352NV, which pads and rotors did you wind up getting? I just got my irotors in Friday, but still deciding on the Pads. I have a set of PBRs in Grey, but looking for the dust free. Thanks
Old Jun 27, 2005 | 06:43 PM
GYAL8R's Avatar
Ok here's the new situation.
I talked to "randy" over at brakewarehouse.net today.
For the fronts slotted and drilled rotors they're $176.00 each
For the rears they're $161.00 each -
He recommended knickle platting the rotors for $22.00 extra. I live in SF and the car is parked on the street..and yes we have "FOG" here so he recommended I get them knickle platted.
Now another good thing with "Randy", he offered to send the brakes first and will charge my credit card within a certain time frame.
Has anyone ever used brakewarehouse.net?
Also, is it true that I should get new pads again when these are installed?
Thanks for your help.
BoBs
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
RedBaronK
Jul 27, 2015 03:19 PM
emorehs
Jul 17, 2015 09:45 AM
