Show me your wheels!
Old Feb 11, 2007 | 08:46 PM
  #811
wiz2's Avatar
Tires:Toyo T1R 245/35 F 275/30 R
Rims: 8.5 35offset F/ 9.5 45offset R
Wheels: 51lbs F / 54lbs R (on my bathroom scale)
Got the package from D2autosports.
I think I could have gotten away with a fat tire set up 245/40F & 275/35 but it would have been close with drop.
When I weighed my OEM 18's they were at 50lbs each (on the same bathroom scale).
The ride is amazingly smooth. I was expecting a lot harsher ride due to teh low profile. I have the 43psi in each tire and it feels ever so slightly stiffer than the OEM 18's. But no tire squirm when you get on it coming out of a turn.
Now I'm looking for a comfortable 1" drop and some odds and ends and its a wrap
Old Feb 11, 2007 | 08:52 PM
  #812
(>")> G35's Avatar
Thanks for the info. Looks like weight wise, there wasn't too much of a change over stock. Glad to hear that the ride didn't change much as I also have the sport package. I plan on getting the same tires with the fatter setup you posted, I don't plan on dropping me car right away so the fatter 40/35 setup will keep the stock gap versus the 35/30 setup which would be smaller than the stock diameter. Also get a pic from the back, i want to see how those meats look from behind. Thanks!
Old Feb 11, 2007 | 09:22 PM
  #813
Texasscout's Avatar
Originally Posted by UPandCOMING.G35
What exhaust is that? Borla?
Old Feb 12, 2007 | 08:34 PM
  #814
Gdup35sedan's Avatar
ENVautoDetailing.com
Here's the new Kicks
Sevas S7 Gold
20x8.5 +38 245/35/20 Potenza RE960AS
20x10 +40 275/30/20 potenza RE960AS
Old Feb 12, 2007 | 08:41 PM
  #815
G35Papa's Avatar
Thumbs up
Seva's
I see you stepped it up a notch.
I like that shade of gold. Looks great on IP.
Edit:
More pics please
Edit:
Just saw your other thread!
Old Feb 12, 2007 | 09:36 PM
  #816
labguy94's Avatar
Nice wheels G! As always your photoshoots are awesome with a kewl car. Keep up the great work!
Old Feb 12, 2007 | 09:39 PM
  #817
I definitely would not have 43PSI in each tire for daily driving. Max is 44-50 and that's only if you have a full car, trunk and all. I ran my 19's and now my 20's at 35PSI and its perfect.
At 43psi cold, when the tires warm up they'll be at about 48, which exceeds the maximum recommended psi, so i'd drop it down to atleast 38psi.
-GP-
Old Feb 12, 2007 | 10:21 PM
  #818
G35m@'s Avatar
Sweet **** wheels - not a fan of the gold, but it's a good look for your car.
[QUOTE=Gdup35sedan]Here's the new Kicks
Sevas S7 Gold
Old Feb 12, 2007 | 10:23 PM
  #819
BuckeyeG's Avatar
They look great gold. Makes a nice contrast.
Old Feb 12, 2007 | 10:36 PM
  #820
Chico's Avatar
Thumbs up
Sevas S7 Gold
looking good bro. I had a feeling you were getting the Sevas.
Old Feb 12, 2007 | 10:39 PM
  #821
wiz2's Avatar
-GP-
My Toyos have's a max psi of 50lbs. It was 28 degrees at 6am and 64 degrees by 2 pm this afternoon they went up 47psi. I'll continue to monitor as temps increase in the summer. May drop it pound or 2 or try nitrogen which deviates less. Yes I'm feak about tire pressure and making sure tires wear evenly.
Old Feb 12, 2007 | 10:42 PM
  #822
Running too much PSI in the tires is going to wear the middle of the tread more than having even wear. Too little and the sides wear faster, that's why i suggested 35psi, i've put 35psi in every car i've worked on in the past 2 years. Its the perfect psi, not too stiff, not too soft. But i geuss if 43 works for you then it works for you
-GP-
Old Feb 14, 2007 | 05:47 PM
  #823
NorthSideRacing's Avatar
Sevas S7 Gold
i like your new shoes. i just purchase me some new shoes this week. i went from 19's to 20's and now im going back to 19's.. ill post pics when i get them mounted....
Old Feb 14, 2007 | 08:31 PM
  #824
g35sedan5at's Avatar
i really do love gdup35sedan's new wheels, absolutely amazing, but do we have to keep quoting them...this is basically a whole page of his pics being reposted and reposted!
Old Feb 14, 2007 | 09:23 PM
  #825
Floyds_racing's Avatar
Damm Grant they need to hurry up and give me my money so I can get my car painted! Im trying to get the S-22 Sevas in black for it too. I wanted those to start should have paid a few more dollars for them!
