Installed Hawk HPS Brake Pads
Originally Posted by afr0puff
In the dry they are fine. Just be sure to double pump in the wet under the same temps. There is zero brake feel on the first try. Sucks after you need to come to a quick stop from 50+mph.
I replaced my stock Brembo pads at 18K miles with Hawks. I too didn't have my rotors re surfaced and they sqeeled like crazy. At 25K I replaced my rotors with Brmbo slotted and it's hardly squeeled at all since and stops great. Moral of the story...replace your rotors or have them resurfaced when you do the pads for the best performance and least amount of noise. JMHO
Originally Posted by G3NIU5
double pumping could mean air in your brakelines, bleeding needed. not necessarily the pads. i have the hawks and drove thru a lot of rain recently, and around 50s temp, same performance as dry.
^i too have the brembos. but i had the crossdrilled brembos at the same time w/ my hawks so we may have diff setups.
my short review: the hawks are not grabby like the oem pads were, no more unnecessary neck snapping stops, but when u need to step on it, it'll stop on a dime. and modulation is much easier. no squeaks so far and so little brake dust compared to oems.
Nah, my brakelines are fine. They were bled at the start of summer. The hawks are fine in the dry, otherwise I would feel the same weak pedal if there were air in the lines. But it's not just me regarding the HPS pads in cold wet weather. Others in my area reported the same thing with the recent rain we had. BTW, I have the brembos so I'm not sure if that has anything to do with our different experiences with these pads.
Interesting...
I just put my Hawk HPS pads in this W/E. No problems with braking so far when cold (it was about 27 F this morning). Not sure about wet conditions.
BTW, for the non-Brembo pads, is it normal for only one of each pair to have the 'Pad Wear Sensor'? Nothing to fit the inner spring in on the Pad Retainer for the front brakes?
"BTW, for the non-Brembo pads, is it normal for only one of each pair to have the 'Pad Wear Sensor'? Nothing to fit the inner spring in on the Pad Retainer for the front brakes?"
Anyone with the non-Brembo Hawk HPS pads have an answer?
TIA
TIA
Thanks.
It's been below freezing in the mornings since this W/E. Brakes are fine in the cold so far. Seem to grip a bit better than stock at moderate and high braking pressures. Absolutely no squealing and no noticeable dust since the W/E.
I normally 'bed' the brakes with moderate stops at highway speeds (something I've done for >20 years). This time I used Hawk's recommended procedure, and it seems to do a better job. After my last hard stop for the cool-down, my brakes were smoking, and the anti-squeal goop was bubbling and boiling out of the shim holes!
Also the smell of burning brake pads was apparent.
This has now become my new 'bedding procedure', and I don't have to get out on the highway to safely do it!
Also the smell of burning brake pads was apparent. This has now become my new 'bedding procedure', and I don't have to get out on the highway to safely do it!
Originally Posted by Gordgee
Thanks.
