Brake replacement
Old Nov 5, 2005 | 02:35 AM
GFN-G35's Avatar
Brake replacement
Hey does anyone know how to replace pads and rotors for the brembo package i want to do it myself to avoid costly installs from the shops
im pretty sure its not that hard just wondering if anyones done it and could help me out
THANX in advanced
Old Nov 10, 2005 | 04:09 AM
G35_Foo's Avatar
g-owners.com should be a write up on there
Old Nov 10, 2005 | 03:25 PM
nas4a's Avatar
As said, there are some good write-ups on a few of the forums. Sorry I can't direct you to where, but I can say this, I've never done a brake job in my life, but after doing it once and seeing how easy it was, I'll never pay for another one again.
My dealer quoted me $500 for front brake pad replacement. For less than that, I got cross-drilled Brembo front rotors, and front AND rear Hawk pads. I installed them myself in a little under 3 hours with air-tools in my garage on jack stands.
Old Nov 10, 2005 | 03:49 PM
GHBG35's Avatar
Just be patient and tender bolting the caliper back on. Other than that it is simple. You really don't need to read a DIY, just take it apart, pretty hard to screw it up.
Old Nov 10, 2005 | 04:17 PM
shibal_z's Avatar
Rotor/Pad replacement
I helped a friend replace his rotors and pads on his WRX a few weeks ago. I would say it's pretty easy in terms of complexity.
You will need a clamp and one important thing.... You need to use brake cleaning fluid to wipe down the rotors. I believe the rotors will come oiled to prevent rust, but you need to wipe out all that oil before it comes in contact with your new brake pads. My friend forgot this part and now he has to buy new pads. The risks of DIY.
Good Luck!
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Patrick Bovee
Aug 7, 2015 11:16 AM
RedBaronK
Jul 27, 2015 03:19 PM
itschuckster
Jul 25, 2015 08:07 AM
