SPC Camber /w Toe Bolt Specs
Old Nov 1, 2005 | 02:49 PM
lucidazn's Avatar
I searched the forum and I couldn't find the specs for this kit so I called SPC. If you plan on lowering the car by an inch to inch and a half with this kit, use these specs and go from there:
Caster: 7.75 +- .75
Front Camber: -.08 +- .75
Front Toe In: .08 +- .08
Rear Camber: -.58 +- .5
Rear toe In: .22 +- .22
Hope that helps someone.
Old Nov 1, 2005 | 03:41 PM
IAPDirect.com's Avatar
Caster: 7.75 +- .75
Are needing the adjustment specs for this kit or ??? Wasn't sure what you meant.
Old Nov 1, 2005 | 03:46 PM
lucidazn's Avatar
I needed the adjusments and I couldn't find it. So I called them. Thought posting these numbers up would help someone in the future if needed.
Old Nov 1, 2005 | 08:08 PM
Diesel1's Avatar
Moderator
BTW IAP, I recently purchased the SPC camber kit from you guys and I must say the price was the best anywhere and the parts came ridiculously fast! Great doing buisiness with you guys!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
DRG35R
Sep 16, 2015 05:33 AM
