Suspension Tuning
Old Nov 3, 2005 | 06:55 PM
636Racer's Avatar
Suspension Tuning
I just thought that some of you could benefit from this
http://www.drifting.com/forums/showthread.php?t=4943
crediting driftaholic of www.nopistons.com
-and-
http://www.se-r.net/car_info/suspension_tuning.html
by Mike Kojima
Originally Posted by theflatlander
Front spring rate increase:
More under steer; increase in proportional weight transfer to the front when rear wheel rate is not increased; reduces front traction when rear rate is not changed.
Usable adjustment: 150-600 lbs/in
Symptoms of too much adjustment: terminal under steer; front of car hops in corners; excessive wheel spin on inside front tire on FF cars.
Front spring rate decrease:
Less under steer; decreases proportional weight transfer to the front when rear wheel rate is not increased; increases front traction when rear rate is not changed.
Symptoms of to much adjustment: Too much over steer; over steer then under steer if spring is so soft that the car bottoms out on lean, car bottoms out excessively with a jolting ride.
Rear spring rate increase:
More over steer; increase in proportional weight transfer to the rear when front wheel rate is not increased; increases rear traction when front rate is not changed.
Usable range: 100-600 lbs/in
Symptoms of too much adjustment: too much over steer; sidestep hop in corners; twitchy; pretty scary.
Rear spring rate decrease:
Less over steer: decreases proportional weight transfer to the rear when front wheel rate is not changed; increases rear traction when front rate is not changed
Symptoms of too much adjustment: car under steers; if way to soft car under steers then over steers as car bottoms out on lean; car bottoms out excessively with a jolting ride.
Front anti-roll bar stiffer: more under steer
Usable range: none to 1.25 inches in diameter
Symptoms of to much adjustment: terminal under steer; lifts inside front tire off the ground witch can cause massive wheel spin on FF cars; also not good for most effective tire usage as inside tire is now doing nothing.
Front anti-roll bar softer: less under steer
Symptoms of to much adjustment: overstate scary; more like fun
Rear anti-roll bar stiffer: more over steer
Usable range: none to 1 inch in diameter
Symptoms of too much adjustment: Big-time over steer. Can cause inside rear tire to lift off the ground.
Rear anti-roll bar softer: less over steer
Symptoms of to much adjustment: under steer; slow and boring
Front tire pressure higher: less under steer by reducing slip angels on most tires
Usable adjustment: up to 55psi hot
Symptoms of too much adjustment: no traction- tire crowned so more under steer; adds wheel spin in FF cars; jarring ride; center of tire wears out
Front tire pressure lower: more under steer by increasing slip angles on most tires
Usable adjustment: not less then 20psi
Symptoms of too much adjustment: edges of tire wear quickly because tire is folding over; feels mushy; tires chunk because low pressure means heat build up.
Rear tire pressure higher: less over steer by reducing slip angles on most tires
Usable range: up to 45psi hot
Symptoms of too much adjustment: no traction—tire is crowned so more over steer; bad wheel spin on FR cars; jarring ride; center of tire wears out.
Rear tire pressure lower: more over steer by incresing slip angles on most tires.
Usable range: not less then 20psi
More negative camber front: less under steer because of better lateral traction as tread is flatter on the ground under side load.
Usable range: up to 3.5 degrees negative
Symptoms of too much adjustment: poor braking; car is road crown sensitive; twitchy; front tires wear on inside edge
More negative camber rear: less over steer because of better lateral traction as tread is flatter on the ground under side load. More rear grip
Usable range: up to 2.5 degrees negative
Symptoms of too much adjustment: more over steer; car feels twitchy in back; tires wear out on inside edge; less breakaway warning when limit is exceeded.
Ride height to low (typical beginner mistake): car is twitchy with unpredictable dynamics. Bump steer make you life miserable.
Usable range: usually 1.5-2.0 inches lower then stock unless car has been modified to go lower.
Symptoms of too much adjustment: everything that could possibly go wrong: sudden over/under steer; twitchy due to bump steer; very harsh ride; premature tire wear.
Toe in – front: car is stable going straight. Turn in is average
Usable range: 0-1/8th inch
Symptoms of too much adjustment: car has slow twitchiness under braking; feels odd; kills outside edge of tires
Toe out – front: Car turns in well; works pretty well on FF car as they tend to toe-in under load.
Usable range: 0-1/4 inch
Symptoms of too much adjustment: Car is really twitchy under braking; car wanders on straight road; kills inside edge of tire
Toe in – rear: car is less likely to over steer when the throttle is lifted
Symptoms of too much adjustment: weird, slow, rocking movement in back; feels slow but still unstable; wears outside edge of tires.
Toe out – rear: Helps car rotate useful in low speed and slalom courses; very common on FF pro rally cars.
Symptoms of too much adjustment: not to good for street driving; causes lift throttle over steer; makes violent side to side rocking motions in the rear; tie wears on inside more.
Positive front caster: helps stability; suspension will get more negative camber when turning; reducing positive caster reduces steering effort. (Negative caster is not usable)
Usable range: 4-9 degrees positive
Symptoms of too much adjustment: can increase under steer especially in cars with wide low-profile tires. Can increase steering effort.
Single adjustable shock stiffer: Better turn in; better transient response; causes slower onset of over/under steer by slowing weight transfer depending on what end of the car is adjusted.
Symptoms of too much adjustment: suspension becomes unresponsive; ride gets harsh; car skips over bumps, loosing traction; Causes a big delay in weight transfer resulting in strange handling like under steer then late corner stage over steer.
Single adjustable shock softer: slower transient response; quicker onset of over/under steer
Symptoms of too much adjustment: car oscillates due to under dampened spring motion, like a boat. Car gets twitchy in turns. Feels unstable.
Have fun tuning your suspention. Use Toe and Camber to your advantage! Even Tire pressure helps.
crappy thing is, it's based for FF cars. Ideas, theories, concepts are almost the same. happy tuning.
Old Nov 3, 2005 | 11:18 PM
Teeter's Avatar
Sticky please! (Nice job 636!)
Old Nov 3, 2005 | 11:30 PM
808HerbzG35's Avatar
Thanks 636.
Old Nov 8, 2005 | 04:02 PM
Teeter's Avatar
I'm gonna keep bumping til this gets a sticky!
Old Nov 12, 2005 | 03:02 AM
Gsedan35's Avatar
Tuning is a receipe, that requires trial and error to know the receipe is correct for your application and the willingness to validate. Theirfore be open minded and ready for that process to possibly take you down a path that you would not entirely expect to be taken. This platform does not follow the general rules, which is why the aftermarket companies are not all doing specs that are following the same path.
Old Nov 14, 2005 | 02:24 AM
636Racer's Avatar
I already wrote that this was particularly based on an FF platform, a sentra at that. It does make some notes to rwd. Principles still apply.
Old Nov 14, 2005 | 10:27 AM
Gsedan35's Avatar
Of course the principles still apply, as a base line starting point were you have to prove said change was better. And that doesn't mean actual application on the FM platform net's the intended reslults that said change is supposed to bring about. Their are some very nice books on the market that should be read on the subject, race car engineering, tune to win ect. All of them speak on those princple's. BUT, they all tell you to validate that a given change was the RIGHT change. Which is time and money not everyone is willing to spend, though they should in the pursuit of improvement.
Old Nov 14, 2005 | 02:00 PM
kenchan's Avatar
Gsedan35's right. while you guys are buying all these new parts and camber kits, etc. etc. how many of you are actually playing around with the camber and toe settings to dial-in your setup? how about damp and swaybar settings?
how many of you with coilovers are getting their cars professionally corner balanced?
how many of you have actually spent the time needed to dial in your setup?
Old Nov 14, 2005 | 03:49 PM
636Racer's Avatar
I dunno, I've been weighting, calculating, testing and, adjusting my setup for some time now. As track conditions change, so does my setup. I've been very blessed that I have the right facilities and the people to help me. Not too many people know how to properly do a baseline setup their own coil over setup. Suspension setup has always been my forte with motorcycle road racing, I've since applied my knowledge since I've been volunteering my time with setting up formula and spec race cars at our race school, still learning more things about suspension tuning as I go along the way. I've always been faster than guys who made power upgrades to their cars or motorcycles...because I understood their principles, dynamics, and theories. I could always rely on books, but really...I based my theories on experiences. Books and reading are practicalities in knowing how and what things do...but applying them yourself to your specific driving habits will always be different from books. I know where you guys are coming from, I insist that people make their changes baselined from given examples (principles) as such given by members on this forum and take other information such as the one I posted into heart...but futher change them to suit yourself. No one here drives like kenchan, Gsedan35, or myself. You know? What may work for you may not work for me. Some people may take the time, some people could care less. I just thought the relative information, the priniciples, would benefit those who cared.
Old Nov 15, 2005 | 03:59 PM
Teeter's Avatar
Point well taken. As a relative newcomer to suspension tuning, I'm learning a lot from you guys and reading as much info as I can find. I've got a decent mechanic but he's not a suspension "guru" or anything. I wish I had someone locally who really understood this stuff and could drive my car to validate (or invalidate!) what I think I'm experiencing. So far, it's pretty much all trial and error.
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
