Tokico D-Spec set-up advice
Old Nov 6, 2005 | 12:56 AM
kenchan's Avatar
636racer- My setup is for street that can take on most driving conditions
around my area. it includes a few hairpins, a couple nice fast exp ramps,
and long sweepers and rural roads. if i was setting up a track car, i would
use a completely different setup.
teeter- i've driven sports tuned beemers but never gotten the chance to
push it to the limit (wasn't my car)....but I can tell you that the ride
quality is much better on mine and less choppy (sports-sus beemers)
on street. my car turns very well with great posture, none of that
factory-like heavy/slow response.
ever since doing this last setup change on my G35C, my Cooper-S's been
very nervous that it might get sold... i don't drive that car much
these days...
Old Jan 27, 2006 | 08:12 PM
Dan_K's Avatar
Good info Ken. Is it better to go with the Dsp9(G35) or Dsp7(350z) shocks when getting the 350Z H-Techs?
Old Jan 27, 2006 | 11:50 PM
CrazyMike's Avatar
Either will work, though, the 350z version D-Specs will be the best match with the 350z H-Techs assuming you will not use them with the OEM springs. The only difference is piston travel. I have the G35 version D-Specs on mine as I was initially planning on keeping my springs OEM.
Old Jan 29, 2006 | 02:08 AM
Dan_K's Avatar
Oops..DSP7's are for G35's and DSP9's are for 350Z. Just double checked.
Old Apr 20, 2006 | 02:00 PM
OC 350GTCoupe's Avatar
Just to make sure. The turns that everyone is refering to is from full stiffness? So 4R 3.5F would be 4 turns from full stifness in the rear, and 3.5 turns from full stifness in the front??
Old Apr 20, 2006 | 02:15 PM
robbdogg's Avatar
Yes.
Old Apr 20, 2006 | 08:32 PM
Deang35c6's Avatar
I have 4.5 rear and 4.45 front. I'm running Tein S-Tech for the 350Z. I needed the best compromise between street handling and drag strip racing traction. The softer rear will allow the rearend to squat when racing from a dig.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
