Tanabe Coilover
Old Nov 21, 2005 | 10:17 PM
Orlando333's Avatar
Tanabe Coilover
Anyone have the Tanabe Pro Seven Active Suspension installed. If so, where did you get them.
Old Nov 21, 2005 | 11:03 PM
buckwildg's Avatar
i dont think they are out yet. was talking to a shop and they said maybe beginnning of next year.
Old Nov 21, 2005 | 11:23 PM
Orlando333's Avatar
they are selling them for the 350z; but the dealer said they won't work for the g35 is that true?
Old Nov 22, 2005 | 11:49 AM
SI_G35Coupe's Avatar
interested in this as well, i just read an article on them in one of the car mags, sounded really interesting
Old Nov 22, 2005 | 02:00 PM
roneski's Avatar
Devil's Advocate
Spring rates would probably be different for a G35 since we are a few hundred pounds heavier.
Old Nov 22, 2005 | 09:09 PM
636Racer's Avatar
Try taking a look at SilkRoad RM/A8 coil overs. You can spec your own spring rates. The FLA-2s are just about the same thing, but the RM/A8 are cheaper and they're better built. IMO, they're pretty hardcore, but sane enough to be used on the street at a softer setting. Also, JIC coilovers have a reputation for crapping out early on and, I dont know if they've changed their ways of construction.
www.silkroad-usa.com
Old Nov 24, 2005 | 11:37 PM
the tanabe system is similar to the Tein EDFC setup, but even more flexible b/c it allows you to dial in your damping based on speed. so it could be softer at low to medium speed and firm up as you accelerate.
Old Sep 4, 2007 | 10:48 PM
06PlatinumG's Avatar
bump.......Was doing a search on the Tanabe Pro Seven, does anyone have them on there G? I'm considering them and would like some feedback
Old Sep 5, 2007 | 11:26 AM
Drewer's Avatar
Yes. Search. Hint: you can use my name as the thread author.
Old Sep 5, 2007 | 01:49 PM
j-ondemand.com's Avatar
heres the 411 on those. For the G35 there good in stock. Your gonna need to cut away a little of the inner liner/shield at the top to get them in. No big deal. just given you all the heads up have a good day
martin
Old Sep 5, 2007 | 02:35 PM
wayneside's Avatar
hit up sam @ invision...they have good prices on everything...
his aim sn is invision sam
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
