Espelir Springs
Old Nov 25, 2005 | 12:55 AM
G35zkyline's Avatar
Question Espelir Springs
Hey guys I am thinking to swap my H TECHS for the ESPELIR GT springs cuz I like the idea of a higher spring rate, and i found this info in a different forum.
I would really appreciate some imput.
here it goes:
Where'd your idea of what the oem rates come from? Their on the low side, 4-5Kg of course equal's 224lbs-280lbs. The oem spring rates are in fact 314/342. When picking springs or coilovers for any FM platform vehicle, buyer beware, some products transfer a awefull lot of roll stiffness to the front.
The S-tune may have better valving in them, but you make a trade off with the progressive springs they use.
Oem spring rates
Front:314 Rear:342
Nismo S-tune (uses progressive springs, especially in rear)
448/504 F+43% R+48%
Transfers +5% roll stiffness to rear
Eibach's as noted (first number is the softer initial rate, followed by the higher final rate)
350Z 296/384 front 316/421 rear
G35c 229/337 front 274/463 rear
G35s 259/334 front 359/413 rear
RSR 350Z springs (just a wee bit progressive F&R, maybe one coil is progressive, but not actually looking at pics of the springs)
345/417 F+10% R+22%
Transfers +12% roll stiffness to rear
RSR G35 coupe springs (progressive front and rear)
315/315 F+0 R-8%
Transfers +8% roll stiffness to front
Hotchkis 350Z springs (linear springs)
340/330 F+8% R-3%
Transfers +12% roll stiffness to front
Tein S-tech 350z (fronts are progressive, rears are linear)
386/402 F+23% R+16%
Transfers +7% roll stiffness to front
Tein H-tech 350z (fronts are progressive, rears are linear)
358/375 F+14% R+11%
Transfers +3% roll stiffness to front
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
324/260 F+ 5% R-22%
Transfers +27% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
358/274 R+14% R-18%
Transfers +32% roll stiffness to front
Tanabe GF210 Series 350Z
336/375 F+7% R+10%
Transfers +3% roll stiffness to rear
Tanabe NF210 Series 350Z
314/353 F+0 R+3%
Tanabe NF210 Springs G35 COUPE
297/336 F-5% R-2%
Tanabe DF210 Springs G35 COUPE
308/353 F-2% R+3%
Transfers +5% roll stiffness to front
Tanabe NF210 Springs G35 SEDAN
297/269 F-5% R-21%
Transfers 17% roll stiffness to front
Tanabe DF210 Springs G35 SEDAN
286/280 F-9% R-18%
Transfers +9 roll stiffness to rear
Kg/mm springs 350Z
DR21 super sport 15mm drop
246/398 front 252/409 rear
Kg/mm springs 350Z
DRacing 30mm drop
252/454 front 252/482 rear
Espelir coupe springs (the U.S. importer recently changed specs, I do not believe the newly listed specs are correct, since the new one's are extreamly high. And when I called the company to ask if the springs are linear or progressive, they told me Linear, turn's out they were absolutley wrong, they are in fact progressive. I show the old specs for those reasons, take it with a grain of salt, same thing for the 350Z fitment)
409/460F F+30% R+37%
Transfers +7% roll stiffness to rear
Espelir 350Z springs
381/460 F+22% R+37%
Transfers +15% roll stiffness to rear
Tein Flex
672/672 F+114% R+98
Transfers +16% roll stiffness to front
Tein Flex JDM specs (can be special ordered est 6-8 weeks delivery)
560/560 F+78% R+64%
Transfers 14% roll stiffness to front
Tein Basic
504/504 F+61% R+43%
Transfers +18% roll stiffness to front
Tein CS (Monotube)
392/392 F+25% R15%
Transfers +10% roll stiffness to front
Posted by: jasonintoronto Aug 21 2004, 07:37 AM
wow - excellent information
Posted by: jkoc Aug 21 2004, 07:38 AM
outstanding info
Posted by: Gsedan35 Aug 21 2004, 02:45 PM
Your welcome, I somehow left off a whole page of specs, I ment to post the info below in my original reply.
Buddy Club Racing Spec coilover (Monotube)
748/280*
(very likely run's rear springs on the dampner body and not at the oem rear spring location)
Jic Flta-2 350Z fitment (Monotube)
560/672 F+78% R+98%
Transfers +20% roll stiffness to rear
Jic Flta-2 G35 coupe (Monotube)
560/560 F+78% R+64% $1750
Jic Flta-2 G35 sedan (Monotube)
504/392 F+61% R+15%
Transfers +46% roll stiffness to front
Cusco Zero 1&2
560/392 F+78% R+15%
Transfers +63% roll stiffness to front (no they do not run their rear springs on the dampner body, oem location, seen them on the car with my own eyes.)
HKS LS+ (rear springs are progressive)
496/440 +58%front +29%rear
transfers 29% roll stiffness to the front
HKS LS G35
448/336 43%front -1%
transfers 44% roll stiffness to the front
HKS LS 350z
448/448 43%front +31%
transfers 12% roll stiffness to the front
HKS II 504/504 +61%front +47%rear $1600
transfers 14% roll stiffness to the front
KW coilovers Variant's 1,2&3
Variant 3's are noteworthy as the only known coilover for these cars where the dampners are adjustable for compression and rebound independently. They also differ in using progressive springs front and rear
Front: 485lbs to 525Lbs Rear: 240Lbs to 548Lbs
D2 Racing Coilovers (Monotube)
840/728 F+168% R+113% (wee bit stiff eh, the recommended rate to)
Transfers 55% roll stiffness to front
Old Nov 25, 2005 | 03:23 AM
KrazyKorean's Avatar
lol thats alot of info. Espilir GT springs are great, I had them on my s2000 but changed to Coils since they give my adjustability. But anyways, espilirs are a little stiffer but not harsh at all. I dont know if that helps or if thats the answer you want, but thats my experience.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
