05 G35 Sedan 6MT spring and shock question...
Old Dec 7, 2005 | 10:14 PM
Chongwon's Avatar
hello,
I have a 05' G35 6MT...
I want to change my spring and shock absorber and add stabilizer..
I think the EIBACH is good for spring...
Please recommand makers and model name of absorbers and stabilizer...
Also one more question...
Do I have to buy camber adjust only if use EIBACH spring and koni shock absorber to drop just around 1.1''?
Please reply~~
Old Dec 8, 2005 | 01:46 PM
Gsedan35's Avatar
Oem 350Z springs will drop you close to the same amount as the Eibach springs and give you much more consistent feel. For shocks I would go with Tokico D-specs. Koni's are much more expensive and I don't see anything in play to suggest that you need to pay extra for them. On oem Z springs I was able to align the car close to oem coupe specs, but just outside of sedan alignment specs. For sway's go with Stillen, fully adjustable front and rear with built in collars. Hotchkis and EVO350 are two other good bar choices but do not come with the built in collar's that the Stillen's have, though you can add collar's to them it's a extra step you may not want to get into.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
nervseele
Jul 17, 2015 11:21 PM
