New rotors?
Old Dec 8, 2005 | 01:47 AM
aikon012's Avatar
New rotors?
So I've been dong some research on brakes since it seems that my rears need to be replaced and I'm about to replace them along with the fronts with some Hawk pads. I've just been looking and when is it reccomended to change the rotors? Is there any way to gauge wear on the rotors or are you just suppose to change them at a certain time? thanks
Old Dec 8, 2005 | 01:59 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You need to get your rotors measured with a MICrometer. Most automotive shops that do brakes should have a MIC handy and be able to tell you if the rotors are machinable or if you just need to replace them.
-GP-
Old Dec 8, 2005 | 08:35 AM
Dudefish's Avatar
Look for a thread I was the author of a few weeks back, somebody posted the actual original thickness and minimum thickness specs. I wrote down 0.902" on a scrap of paper on my desk but I'm not sure if that was my measurement or the minimum spec or what.
Old Dec 8, 2005 | 09:17 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
>>from sedan manual
Rotor Wear limits
Max run out > .035mm
& rotor wear limit = 22mm (thickness)
max uneven wear (measure @ 8 points > .015mm
Old Dec 8, 2005 | 11:30 AM
Endless G's Avatar
>>from sedan manual
Rotor Wear limits
Is this info from the FSM!?!?
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
