reinforcement braces
Old Dec 9, 2005 | 04:45 AM
Sasanpasta's Avatar
does anyone have any of these reinforcements braces?
http://performancenissanparts.com/ca...oducts_id=2462
http://performancenissanparts.com/ca...oducts_id=2464
http://performancenissanparts.com/ca...oducts_id=2463
i am intertested in getting some cuz i noticed that my frame bends when i go up drive ways at an angle cuz i have sway bars. does this get rid of the bending sound?
Old Dec 9, 2005 | 11:15 AM
kenchan's Avatar
your bending sound could be coming from your swaybar bushing and bracket.
might want to re-lube them.
unless you have stiff sus setup (like over 450lbs/in) you're not going
to get much benefit from adding braces.
Old Dec 9, 2005 | 10:35 PM
Triple8Sol's Avatar
Yup. I have the FLTB/RLTB on. I'm gonna be selling the rear lateral arm brace, b/c it won't work w/my stock exhaust.
https://g35driver.com/forums/brakes-suspension/77521-sways-ltbs-installed-lift-w-pics.html
Old Dec 10, 2005 | 09:21 PM
Sasanpasta's Avatar
how do u relube the front sway bar? i have the hotckis sways and there is only a grease fitting on the rear sway. should i take off the bolts holding the sway bar and open the bushing and put lube in it? or is there an easier way?
carid
Aug 22, 2016 01:34 AM
ScraggleRock
Sep 3, 2015 03:12 AM
IS300TOG35
Jul 11, 2005 12:16 AM
