Help!!!
Old Dec 19, 2005 | 06:43 PM
SooMighty's Avatar
Help!!!
I changed my stock rims to some volks last week. but before I put those stock ones on, I had to take out my other old volks out to put the stock ones on. Ever since I put the stock ones back on, the (!) light has been on. the tire pressure and everything isf ine cuz they are new. the dealer said they charge $130 to reset or whatever. anyone else have this problem when taking off/putting new wheels? the first time I took out mu stock rims and put volks a year agi this didnt happen. but this time around its not the same story. the dealership told me to ignore the light but sometimes its nerve wrecking.
Old Dec 19, 2005 | 11:58 PM
kenchan's Avatar
does the DTC show up in the ODB2 scanner as any of the below
chassis codes? if so, you can clear them but if theres no transmitter
in the tire, you'll get the same codes again.
C0750 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0755 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0760 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0765 - Tire Pressure Monitor (TPM) system sensor not transmitting
