Why 350Z H-Techs over Gcoupe H-Techs?
Old Jan 15, 2006 | 12:06 PM
  #31
Endless G's Avatar
Are they the proper install for the sedan?!?!
Old Jan 16, 2006 | 12:55 AM
  #32
Sponger's Avatar
6MT Brembo Coupe
Originally Posted by Cactus
Could you possibly post more pix on flat ground?
Sorry, no flat ones. Another one in the driveway.
Old Jan 16, 2006 | 12:58 AM
  #33
Sponger's Avatar
6MT Brembo Coupe
Not sure what you mean.
Old Jan 16, 2006 | 11:46 PM
  #34
diggy1's Avatar
2 questions. 1 request. ANY CAMBER/TOE ISSUES WITH THE Z H-TECHS (if so, which kit should I go with)?
ARE THE Z H-TECHS COMPATIBLE WITH STOCK SHOCK AND STRUTS (if not, what are you guys using)?
PLEASE POST PICS OF Gcoupe ON Z H-TECHS.
Thanks
Old Jan 22, 2006 | 08:24 PM
  #35
ProjectFusion's Avatar
Florida G35 Club, Premier Member
Thanks
same question
Old Jan 22, 2006 | 09:30 PM
  #36
haze's Avatar
the z h-tech is definitely compatible with the stock shock and struts. In fact, do you mean strut bar? Because I do not think the g35 comes with stock strut tower bars.
Old Jan 22, 2006 | 09:50 PM
  #37
sage's Avatar
Thanks
Anyone able to answer the first question definitively? Some say they have camber/toe issues and other say no. Is it that the numbers are so close that some cars get back to spec while others are just a tab off...
Either way, what's the best kit to get for the front and the rear? Any advantages in getting one kit verse another?
Old Jan 23, 2006 | 08:33 PM
  #38
CrazyMike's Avatar
sage -
For me no problems with camber or toe. The fronts are technically a bit out of spec as I have about -1.6 degrees one one side and -1.3 degrees in the other. I think the max spec is -1.25. I think the only reason the front camber specs are less than the rear is to keep the safer understeer bias - I don't think there is any harm in running a bit more negative camber up front than spec allows as long as the toe is good and the rear has a tad more negative camber. My front toe is fine - I'm running with zero toe. The rears had plenty of toe and camber adjustment left. I think when I did the initial drop the rear camber ended up at -1.8 degrees, but I had them move the rears out to -2.0 degrees camber for a little better oversteer mitigation. I'm running the rear toe at +.14 degrees (toe in) total toe.
I can't really talk about the alignment kits. I know the best front A-arms are the 350evos - no contest. You'll have to search for the other parts. There are many, many discussions discussing alignment kits.
Good luck! Here are the pics of mine on 350z H-Techs.
Old Feb 23, 2006 | 12:01 PM
  #39
Endless G's Avatar
This thread seems very helpful, so i will just try to ask a favour?!?!?
Does anyone here have a pic of sedan dropped with 350Z H-Tech Spring?!
If you do, how is the ride? Are they rough or bumpy??! Is it better if i combine it with a set of Tockico or Koni Shocks?!?!
Thanks in advance!?!
Old Feb 23, 2006 | 01:20 PM
  #40
CreativeAutoworks's Avatar
Thanks
1.) It is very close in terms of whether you need a camper kit or not, since it is very very slightly off if off at all I would suggest the cucso(retail $459), great product, just doesn't have the amount of adjustment that the 350evo(retail $849.95) has, but if your just off then it will get you back into spec.
2.) Yes you can use your stock shocks, however anytime you lower your car with aftermarket springs we also recommend upgrading your shocks to either the Koni yellows, or the Tokico Specs.
Old Feb 25, 2006 | 07:21 PM
  #41
ksig113's Avatar
Wow a lot of good info on this thread.
Sponger - great looking car. That drop is exactly what I was looking for. Quick question - any issues with speed bumps rubbing your car?
Old Feb 25, 2006 | 10:41 PM
  #42
Sponger's Avatar
6MT Brembo Coupe
Thanks. I do not rub at all even with my daughters (or adults for that matter) in the back.
Old Feb 25, 2006 | 11:52 PM
  #43
Endless G's Avatar
Do you have any aftermarket shock with the setup?!? How is the ride?!
Old Feb 26, 2006 | 01:57 AM
  #44
johnjayb's Avatar
so there are 350z H.Techs. and 350z H.Techs (revised)??? whats the difference?
Old Feb 26, 2006 | 03:13 AM
  #45
Sponger's Avatar
6MT Brembo Coupe
I'm still runnin' stock shocks. The springs feel slightly firmer than stock and you definitely know they're there on bad roads.
John, didn't know they revised these springs. Maybe you're talking about the stock Z springs?
