creaking from rear suspension.
are my shocks blown? there's a creaking noise that comes out of my rear suspension every time i go over a speed bump or take a turn that causes the body to roll sllightly. I have a '03 coupe w/ tein flex suspension. the ride doesn't feel any different.
maybz a loose axel. it's a TSB. have you tried removing, and re-installing the flex's? the only way the Flex's will blow is if you drive through Hau Bush frequently, or have a fetish for potholes.
I have a similar noise coming from my rear passenger side as well. Kinda hard to describe the noise but I guess a 'creak' is as close as I can come up with. No matter how slow I go when turning right, into an incline, I get the noise.
Any ideas to what it is as I'm bone stock on my suspension? The car drives great and I wouldn't have even noticed the noise if I didn't have my radio turned off one day.
ssk0771 its not the axle thing for mine at least because i had that TSB taken care of even though it never did happen to me.
I'm reviving this thread because I have this problem as well. I just recently installed 350 htechs and hotchkis sways. I get creaks in the rear when I go over speed bumps, driveways, etc.
beangrower, have you solved the creak problem?
If anyone else has a solution, or an idea let me know.
I am going to re-grease the rear sway bushings and hope the creaks go away... where do I get grease?
is the tsb for a clicking rear axle the same thing for the creaking sound? my car seems to creak when i accelerate and decelerate at low speeds, it doesnt sound like anything is clicking
I have the same issue...and also an appointment on Wednesday w/ the dealer to check out. I didn't know about the TSB, so I'll print that out and bring it in with me.
I would like to know if only those of us with aftermarket suspensions are having the problem. I have an Eibach pro-kit suspension w/ stock shocks (for now).
DEZ
DEZ
