Using stock springs again..
Old Jan 9, 2006 | 12:38 PM
Brian-g35's Avatar
Lowered my car with the Tein S-Tech, Back wheels camber kinda off and I'm putting back my stock springs on. After stock springs are on would my camber go back to normal or i have to take it to alignment shop? hand or machines alignment?
Old Jan 9, 2006 | 02:24 PM
afr0puff's Avatar
Supa Dupa Moderator
If you never adjusted your camber or had an alignment done after the s-techs, then you'll be fine when you go back to stock... unless you hit major potholes or something.
Old Jan 9, 2006 | 02:43 PM
Brian-g35's Avatar
did alignment after 1 week... mechanic said camber little off
Old Jan 9, 2006 | 10:37 PM
zpeedray's Avatar
how low? i have HR progressive springs too low 1-1/2"
if you like sell them to me if they are 1" and progressive ( progressive are the ones tha beging very separated and them they get bigger in the center an more united in the top ) linears are the of the same size from top to bottom or the same separation.
Old Feb 7, 2006 | 08:08 PM
DTrejo's Avatar
Firestone offers a lifetime alignment where you can go in to any Firestone shop to have your alignment done every 6,000 miles. This might be a good thing due to not being able to rotate the tires on the coupe.
jsimonk
Dec 22, 2023 03:49 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
