Eibach Pro-Kit - Professional Installaton?
Old Feb 14, 2006 | 07:46 AM
Mario77746's Avatar
Originally Posted by ballisticus
I just got a quote for 2 hours front, 2.5 hours rear for $300 labor. Plus $70 for re-alignment. So $370 total. I think I will go for it since I haven't done this type of install myself. With the prokit installed, are sways still as important, or do the springs alone do a pretty good job at reducing roll?
That quote is ridiculous. Front take about 1 hour. Rear take 30-45 min max. I helped with my install (don't have a spring compressor). It was by far the easiest of any cars I have owned. We took our time and probably BS'd for a good 30min of the total 2 hours. On the flip side, every shop is out there to make money……
Springs did it for me. Adding sway's will depend on what your looking for. I personally do not have a problem with the current amount of body roll. Install the springs, drive it for a week and make your decision from there. One plus is wheel hop dramatically reduced after the upgrade.
Later.
Old Feb 20, 2006 | 09:35 PM
DJM AutoWorks's Avatar
I installed mine myself at work the back springs are so easy it took me an hour to do the back the front was a pain in the neck took me about 3 hours over all....i also did a 4 wheel alignment after to set everything as close to spec....i also installed my GT spec chassis braces to stiffen her up a little bit
Old Feb 21, 2006 | 07:13 AM
jimmykce1's Avatar
When you installed the springs did you also have to get camber adjustment plates. Did you all leave the stock shocks?
The reason I ask is that I am 06 G35 on Monday and looking to drop the car with the stock tires and wheels. My car will have the sports tune suspension on it. Please give me some advise.
Old Feb 21, 2006 | 07:52 AM
Houston G's Avatar
I got several quotes for just installation: $720, $650, $500, $350, $220, and $200. I ended up paying $160 with no tax. It was installed yesterday (2/20/02). I am extremely satisfied with Eibach Pro-Kit. The stance has been improved dramatically (not too high or low) and the comfort has actually improved from the OEM sports suspension. I will get an alignment on 2/24/06, allowing the springs some time to settle.
Old Feb 21, 2006 | 08:25 AM
robbdogg's Avatar
Who did your install in town? And it sounds like you are pleased.
Old Feb 21, 2006 | 09:20 AM
jimmykce1's Avatar
Did you also install chamber adjustment plates?? Can you also post pictures?
Old Feb 21, 2006 | 09:24 AM
Houston G's Avatar
The following info will save you a lot of time and effort. Please at least let Andy know that I reffered you.
Andy
Team Rush Motor Sports
(713) 972-0711
Richmond and Dunvale
Old Feb 21, 2006 | 10:07 AM
robbdogg's Avatar
Andy
(713) 972-0711
Thanks - and you should clear out your PM box.
Old Feb 21, 2006 | 10:33 AM
Houston G's Avatar
Thanks, I've cleared out my PM.
Old Mar 7, 2006 | 07:11 AM
fastfoursix's Avatar
So-Cal
$370.00 Eibach Pro Kit, and all installation included. PM me for details
Old Mar 7, 2006 | 01:38 PM
kenchan's Avatar
^^ that's a pretty good deal. ($370)
seagrasser
May 3, 2022 09:43 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Kelvin Style006
May 23, 2016 03:47 AM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
cmesidewayz
Sep 29, 2015 09:28 PM
