front upper strut mount?
Old Jan 13, 2006 | 12:03 AM
woshiagni's Avatar
If I want to install a spring/strut combo without decompressing my current set, all I need is an extra pair of upper strut mounts, right?
Do I have to buy OEM or are there aftermarket pillowball mounts I could buy?
Old Jan 14, 2006 | 10:41 AM
kenchan's Avatar
not sure about the compatibility of pillow mounts from other manufacturers and your springs.
therefore, i would do it safe and get the factory upper mounts.
but you may need to compress the front strut a tad to get clearance
unless you're going to take apart the lower control arms. i didn't want
to take anything more apart than i needed so just compressed the
strut a little bit while it was on the car for ease of removal. then
compressed it off the car further to undo the mounts.
you can even rent a spring compressor at autozone or buy one for like
$20. imo, don't waste your money, just use the factory ones you got.
Old Jan 14, 2006 | 12:21 PM
trey.hutcheson's Avatar
I considered doing this as well. Then while I was at the dealer for service, I walked over to the parts department and found out the mounts were $62.50 *each*. So for $125, you could do it. I decided not to.
Old Feb 9, 2006 | 10:30 AM
woshiagni's Avatar
Thx for the responses guys.... ended up reusing the stock mounts. I think Performance Nissan (mynismo.com) wanted $45 each for the mounts but then you also need the other stuff... boot, bumpstop, etc... plus the rear mount plates as well. Just got to be way too expensive!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
netcbc
Jul 24, 2015 01:59 PM
cyrus32
Jul 18, 2015 06:22 PM
