Stainless steel brake lines?
Old Jan 14, 2006 | 10:43 PM
deadmanincbh's Avatar
I did a search and nothing really came up. Now I have been hearing some mix answers but does stainless steel brake line improve performance or do nothing at all? Thank you.
Old Jan 14, 2006 | 11:32 PM
g35doc's Avatar
They improve brake feel. You won't actually stop quicker.
Old Jan 15, 2006 | 07:43 PM
ssk0771's Avatar
ZZ Boy
I recently got a SS brake line on my Z and I really can't tell the difference that much.
The funny thing is that with SS brake line, brake pedal feel little firmer initially but as you press on the brakes pedal more, it feel little more mushy.
I don't think I have a leak because I check all 4 line.
Old Jan 17, 2006 | 03:15 PM
GReddySetGO's Avatar
If it gets more mushy the longer you brake, then you have air in the lines. You don't necessarily need to have a LEAK. But air is still in them from when you changed them. I would bleed them again.
SS lines won't help you stop faster, they are to improve pedal feel and response. And in most cases(street driving) you won't notice any diffrence at all. The diffrence comes when you track. When the brake fluid gets really hot, SS lines won't expand like stock ones will. And thats what helps keep stiff pedal response after long track use.
jilljann1
Jul 21, 2020 08:12 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
