BRAKE pads/ROTORS
Old Jan 17, 2006 | 05:40 PM
nycsan87's Avatar
BRAKE pads/ROTORS
i need to change my brake pads but i dont want to get Brembo pads because i am low on dough...i need to know if anyone knos any low value alternatives?
also can i just resurface my rotors instead of replacing them ?
Old Jan 17, 2006 | 06:14 PM
GReddySetGO's Avatar
www.tirerack.com <-- cheap aftermarket pads
You can resurface your rotors as long as they aren't under the minimum thickness.
Old Jan 21, 2006 | 04:40 PM
Q45tech's Avatar
Scarey that one would consider buying brake pads based on cost......pay for a performance system then degrade it intentionally.
Old Jan 27, 2006 | 08:18 PM
dcutz21's Avatar
Is it true that you should have your rotors resurfaced if you get aftermarket brake pads. That is what the dealer said and they want to charge me a lot of money for them.
Thanks
Old Jan 27, 2006 | 10:03 PM
You should have your rotors resurfaced anytime you change your pads, be it aftermarket or OEM.
Old Jan 28, 2006 | 10:49 AM
Q45tech's Avatar
Because the pad material transfers to the rotor and that is what creates the friction............new/trued cast iron rotors prior to the transfer have very low friction coefficient compared to pad material.
Trueing [minor depth resurfacing] like 0.0015-0.003" is used to clean off old pad material.
"1. Gradually heat treats the rotor and eliminates any thermal shock in the rotor.
2. Burn off volatiles and moisture from the resin that is near pad surface.
This will eliminate “green fade.”
3. Establish a layer of transfer film about a few microns thick on the rotor surface. Shearing of the film during friction is an effective source of friction force. Otherwise, when using a freshly ground rotor without the transfer film, the main friction force would come from cutting, plowing, or scoring the asperities on the rotor surface. This leads to inconsistent braking effectiveness.
4. Mate the two surfaces to a near perfect geometrical match, so that the contact area is high, and therefore the friction force is increased.
5. The performance of a fresh rotor/fresh pad system would be inconsistent. This is due to ever-changing structures and properties of the two mating materials. Bed-in of pads and rotor will form a stable transfer film.
6. If bedding in procedure is not applied, a stable transfer film may not be established for a long time. In other words, the rotor surface would have to be constantly regenerating a film that is not quite stable for a long time. This effect would reduce the performance and increase the wear. "
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
