Sway Bar Question???
Old Jan 18, 2006 | 03:43 PM
XBones's Avatar
I have a '05 AT Coupe with the Sport Package option. I am thinking about installing swar bars when I do the exhaust. My question: Is there an added benefit to having sway bars with the factory sport package? Or should I spend my money on another mod?
Thanks in advance.
Old Jan 19, 2006 | 01:23 AM
haze's Avatar
yes there will definitely be benefit going with aftermarket sway bar, you will expereicen much less body roll with a good brand and you will have adjustability, can partly compensate for understeering or oversteering and general handling.
Old Jan 19, 2006 | 03:58 PM
XBones's Avatar
Does anyone know if the current sport package bar setup is the same bar size as the Stillen? If it is then what is the difference?
Old Jan 20, 2006 | 08:26 PM
Jordaann85's Avatar
i'm pretty sure the stock sways are simliar in size and dimensions to the stillen. but the stillen is stiffer and adjustable i believe.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
linedr89
Aug 17, 2015 05:11 PM
wuppiedog
Aug 7, 2015 11:16 AM
